Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Aftermarket Front Sway Bar Endlinks ...
Old Nov 15, 2003 | 08:16 AM
kungfuSiR's Avatar
Default Aftermarket Front Sway Bar Endlinks ...
I'm looking for a set of aftermarket front sway bar endlinks that will work with my stock 26mm Civic Si sway bar. I've been looking around and have basically come up empty handed, anyone know some good companies to try out?
Thanks
Old Nov 15, 2003 | 09:53 AM
jc836's Avatar
Default Re: Aftermarket Front Sway Bar Endlinks ... (kungfuSiR)
Contact ADDCO. (www.addco.net) They are a manufacturer of sway bars down south. Also take a look in the NAPA and other catalogs for stock replacements. Then there is Energy Suspension.
Old Nov 19, 2003 | 12:14 AM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungfuSiR &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for a set of aftermarket front sway bar endlinks that will work with my stock 26mm Civic Si sway bar. I've been looking around and have basically come up empty handed, anyone know some good companies to try out?
Thanks</TD></TR></TABLE>
for what car is this? i have endlinks which will allow you to use the SI sway bar on other civics without
spending $$$ for a new LCA and damper forks. check it out.
https://honda-tech.com/zerothread?id=677413
The Answer
Honda Civic (2006 - 2015)
18
May 5, 2011 07:34 AM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
dj12oclock
Mar 19, 2008 12:19 AM
zach1288
34
Jul 18, 2007 06:04 AM
MaaseyRacer
Aug 17, 2004 09:40 PM
