brakes=rpms jumping
Old Nov 15, 2003 | 06:43 AM
matix's Avatar
Default brakes=rpms jumping
Last night i was pumping my brakes at idle. I noticed it was reving my car when i was pumping the brakes. It was going from 700 to about 1500 when i was doing this. I have abs brakes if that matters. Please help.
Old Nov 15, 2003 | 12:04 PM
under advisement's Avatar
Default Re: brakes=rpms jumping (matix)
Sounds like your power booster has a vacuum leak. Does it fell like you have to push the brakes any harder to get them to work?
Old Nov 15, 2003 | 04:10 PM
matix's Avatar
Kinda how could i fix
Old Nov 15, 2003 | 05:31 PM
89_LXi's Avatar
Default Re: (matix)
If the booster is leaking, you'll need to replace the booster with a new or used one (should be able to find a good one at the junkyard if you're short on $$). You can check to see if the booster is indeed leaking by unplugging the large vacuum hose from the booster, and hook up a vacuum pump with a gauge (hand pump works fine), pull a small vacuum and see if it holds or not. It shoudn't leak AT ALL. If it goes down any, even after letting it sit for awile, it is leaking and will need to be replaced. If it stays at the exact amount of vacuum for a long time then the booster is fine, but it sounds like a booster issue from what you describe.
btw.... where in S. FL are you at?
Old Nov 15, 2003 | 05:48 PM
accord91lx's Avatar
Default Re: (89_LXi)
on my 91 i can sit there and pump the **** out of them and it'll rev up.. but i have to pump them really fast for it to do it.. yeah i got REALLY bored once... and i dont notice any braking issues....
Old Nov 15, 2003 | 07:36 PM
Starrman85's Avatar
Default Re: (desolate)
i noticed that if i'm idle, and i pump my brakes really fast, the rpm's will go up a couple hundred, but not from 700 to 1500...thats a big jump.
btw, i have a 92 ex.
Old Nov 16, 2003 | 04:26 AM
matix's Avatar
thanks for tha info. Im in west palm beach
gsr1420
Jun 27, 2010 10:36 PM
SideFX
Sep 18, 2009 05:25 PM
Civd16y8
12
Aug 18, 2005 03:00 PM
AcidGord
Dec 24, 2003 10:38 AM
zcpowereddx
Jul 4, 2002 10:35 PM
