How to check code on 89 crx
Old Nov 14, 2003 | 09:51 PM
8ty9CRXDX's Avatar
Default How to check code on 89 crx
I've been getting check light and dont know how to check code. where and what do i look for?
Old Nov 14, 2003 | 11:44 PM
camboMONK's Avatar
Default Re: How to check code on 89 crx (8ty9CRXDX)
passenger side, under the carpet. count the led flashes and look up the code in the manual.
Old Nov 16, 2003 | 11:42 AM
youngwon22's Avatar
Default Re: How to check code on 89 crx (camboMONK)
not enough info...
Old Nov 16, 2003 | 06:56 PM
t3to4e's Avatar
Default Re: How to check code on 89 crx (youngwon22)
pull back the passenger side carpet where there feet would go and there is a brass case look there should be a lil red light that flashes count how many times it flashes then look up the number of flashes and thats your problem
Old Nov 16, 2003 | 08:07 PM
8ty9CRXDX's Avatar
Default Re: How to check code on 89 crx (t3to4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e &raquo;</TD></TR><TR><TD CLASS="quote">pull back the passenger side carpet where there feet would go and there is a brass case look there should be a lil red light that flashes count how many times it flashes then look up the number of flashes and thats your problem</TD></TR></TABLE>
when do they flash? Right when the Engine Check light is on? Or every minute?
Old Nov 16, 2003 | 10:19 PM
Redline130's Avatar
Just turn the key in the ignition to the on position. The red led will flash a x number of times and that will be your code. You can then trouble shoot from there.
DamnThatsRexy
Jun 17, 2013 09:58 PM
vtec-adykt
Sep 6, 2005 10:07 AM
johnle912
Acura TL, RL & ZDX
Mar 31, 2005 03:59 PM
zerospooon
Feb 28, 2002 03:32 PM
