Failed emissions barely on co... help...
Old Nov 14, 2003 | 07:49 PM
NIKE SB'd's Avatar
Default Failed emissions barely on co... help...
Okay guys I barely failed the CO part of the emissions test. I have replaced the spark plugs since then and I didn't have an air filter in the car when I took the test. I have also replaced the air filter since then but should these two things fix the problem or will I need to do more stuff? I was also thinking of replacing the o2 sensor but I really don't know if it is bad. Also I have a VTEC controller but it's not installed because I don't really need it yet, so don't just say to lean out the mixture... ecu and everything is stock also.
Old Nov 14, 2003 | 08:22 PM
NIKE SB'd's Avatar
bump
faran
Apr 25, 2015 08:31 AM
DB1_559
Apr 1, 2011 01:48 PM
integra_type-r
Oct 1, 2007 11:02 PM
built562
May 4, 2004 11:47 PM
IamVtec
12
Nov 2, 2002 01:05 AM
