My dyno sheet and questions
Car is 1989 Honda CRX I made 190.2 whp on a mustang dynanometer and 124.9 tq
Now the cams are cat cams and they are the race ones but by the looks of the sheet they flatline at 8 grand, the tuner told me that past that it is straight so he stopped it there, should I get a cam like the crower all motor ones, please sugest
oh and 1-4 mile guesstimate is appreciated
setup is
b18a b16a
ported and polished, polished cumbustion chamber, 3 angle valve job
titanium retainers, dual valve springs, cat cams full race cams
skunk2 manifold
cam gears
FPR
hondata stage2
510 evo injectors
airmass header (i know i know)
2 14 crimp bent exhaust
test pipe
CTR PISTONS
vtec water and oil pump
what kind of gains will I get with a 70mm tb and a an-r header
thanks
and what you guys think
anyhting is appreciated
b18a b16a
skunk2 manifold
cam gears
FPR
hondata stage2
510 evo injectors
test pipe
CTR PISTONS
thanks
can you post a graph with the a/f ratio. Mustang dyno's give lower numbers than dyno jets. But as long as you are using it as a tuning tool I guess it realy doesnt matter.
On the tb question I think you should look at your goals and buy one that will help you reach them. So you dont by a 65 now and a 75 later. Thats what I had to do and tb's arent cheep.
