home depot trick instead of camber kit for the rear
as the topic foshizzie says what size washer do I need for a 2000 civic si coupe aka EK?
fast responses would be much appreciated.
just get a bunch of thin washers, and use a level to measure the camber, it'll take a couple of tries. Make sure you are on flat ground. ITs also a good idea to get a longer bolt because the washers will leave less thread for the stocker to hang on to.
your are asking a stupid question, stupid questions get stupid answers.
it is pretty self-explainatory what you have to do. look at where you put the washers, get a few that look about the right size. washers are a dime a dozen. I dont see where you could go wrong. it is not going to take very many washers because neg camber in the rear is never all that bad.
and its not much of a trick, more like common-sense.
Dropped90Integra
Suspension & Brakes
Apr 28, 2005 10:18 AM
