Piping diameter question...2.25" or 2.5"?
Old Nov 14, 2003 | 03:13 PM
EXOSPEED:SHARK's Avatar
From: Azusa,CA USA/ Manila Land of the Pick Pockets
Default Piping diameter question...2.25" or 2.5"?
hey whats up guys...Im running a pretty much stock b18b with gsr tranny, and the usual bolt-ons...jdm itr header, 2.25" hks piping with test pipe. I recently picked up a Vision muffler with a 2.5 rear section. I noticed gains all throghout the powerband, mostly mid range and top end. The b18b isn't going to be fully built, but definitely in the NA category. I will eventually add a mild cam, aem fpr., throttle body, in. manifold, and reprogram to OBD-1 spec. Would it be a waste if I went with a full 2.5" exhaust system with my current set-up right now?would I lose/gain power? any input, comments, suggestions will help and be welcomed.
Modified by noVTECinside at 12:35 AM 11/15/2003
Old Nov 14, 2003 | 06:49 PM
SubieDude's Avatar
Default Re: Piping diameter question...2.25" or 2.5"? (noVTECinside)
well if your planing to do a little more...go with the 2.5...there'd be no point to put 2.25 on and then have to change it again..
Old Nov 14, 2003 | 06:59 PM
Default Re: Piping diameter question...2.25" or 2.5"? (WhiteS2)
yah, but how would the car do, performance wise with the 2.5", with the set up I have right now. would I gain or lose power. thats what I'm trying to find out.
Old Nov 14, 2003 | 07:29 PM
WhitEdRift's Avatar
Probably won't gain much sizing up. A little, but not a significant different, although every little bit helps. But if you are later going to add more stuff on you might consider the 2.5" for future sake. The gains will be greater going up.
Old Nov 14, 2003 | 07:34 PM
SIK IN DA HED's Avatar
New User
i would recommend gettin a 2.5 in setup. it wont give you big gains... but its signiticantly worth it. especially in the higher rpms.
Old Nov 14, 2003 | 11:40 PM
Default Re: Piping diameter question...2.25" or 2.5"? (SIK IN DA HED)
cool thanks guys, yah I was thinking about going with a full 2.5 but wasnt sure if i would gain anything at all since the motor is stock. thanks guys
Old Nov 15, 2003 | 01:08 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
You'll be fine with 2.25.
Old Nov 15, 2003 | 06:29 AM
onefstek's Avatar
2.5" all the way will give you a good set up for now and for the upgrades later. 98ctr
hydroflip
May 30, 2007 08:41 AM
-Championship-
21
Feb 13, 2007 04:44 PM
JDMtype Eg6
14
Dec 27, 2006 09:54 PM
SIReg9
Jul 21, 2003 01:07 PM
Volcom
May 4, 2003 12:13 PM
