dart block/ vtec head/wiring
Old Nov 14, 2003 | 12:20 PM
LBR92DA-T's Avatar
Default dart block/ vtec head/wiring
well im building a dart block... my question is i want to put a vtec head on it and my machinist told me that i would not have to run an oil line like the ls/vtecs would.. it would be just like a vtec block.. its going in a 92 integra ls which is obd1 would i have to get a obd1 wiring harness or my friend told me i could just splice in the vtec? i'm leaning more toward getting a vtec wiring harness but anything helps...
Old Nov 14, 2003 | 03:04 PM
hybrid racing's Avatar
if you intend on using an ls bottom end than you will have to approach it as if it was an ls/vtec... the sleeves do not change this part of the swap..
so you have an obd1 ls motor correct?
Since its a 92 i will go ahead and assume it is if this is so all you will need to do is change out the ecu and run a few wires... this is if you have done all the proper oil line running etc etc of the ls/vtec...
Old Nov 14, 2003 | 10:29 PM
LBR92DA-T's Avatar
Default Re: (6spdEG)
i think u misinterpreted it.... but i bought a dart block.. the block is a vtec block... i was just wondering if i would have to change out the wiring...
Old Nov 15, 2003 | 05:09 AM
Soon_2b_evil's Avatar
Default Re: (LBR92DA-T)
the dart block is a vtec block. if i remember correctly its based off a GSR block.
Yes you can splies some wires.
Old Nov 15, 2003 | 07:13 AM
got you... all you need to do is put the head on and run a few wires to the ecu...done
i have an obd1 gsr harness if you are interested pm me thanks.
FOMULA91
Feb 15, 2012 08:13 AM
rico892002
Jun 7, 2007 03:16 PM
poorman's type-r
Jul 28, 2006 04:10 PM
