Best Fitting Header for B16 in CRX?
Old Nov 14, 2003 | 10:59 AM
crxtreme89h's Avatar
Default Best Fitting Header for B16 in CRX?
So what do you guys think is the best fitting header? I don't want to mess with my front cross member. Nor do I want to have the header slamming every curb I go over.
What Year, Make, and Model of car has a header that best fits the B16 in a CRX?
I am pretty familiar with brands, but some suggestions there would be good too.
Thanks in advance!
Old Nov 14, 2003 | 11:07 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: Best Fitting Header for B16 in CRX? (crxtreme89h)
I have a DC 4-2-1 ceramic header and it's already starting to rust (7 monthes old) on my B16 hatch. Some mild modification to the cross member was necessary, though
Old Nov 14, 2003 | 11:57 AM
Default Re: Best Fitting Header for B16 in CRX? (SeaBass)
What year make and model was your header originally for?
Thanks for the reply!
Old Nov 14, 2003 | 10:32 PM
Starbucks_91b16acrx's Avatar
i am also looking into a header for my b16, i heard you would have to modify your crossmember regardless
Old Nov 14, 2003 | 11:29 PM
insomniac791's Avatar
Yea I don't see ya getting a header in there without beating your crossmember in a littlw bit. I have a Comptech 4-2-1 that I am going to use but I also ordered the Place Racing Crossmember so I don't have to worry about it. The header I bought is really for a 99-00 Civic SI if that helps any.
later
Matt
Old Nov 15, 2003 | 12:39 AM
DigitalPunk's Avatar
Default Re: (insomniac791)
You shouldnt have a problem with any 4-2-1 header clearing the crossmemer as long as you get it for a B16. If you order it for a 99-00 si, it will even bolt to your cat. The only problem you will have is being short of one O2 bung. Best thing to do for that is get your ecu chipped, get rid of the speed limiter at the same time.
I had a DC stainless 4-2-1 on my crx when i had my B16A, it fit perfect, and even with teh car extremely low, It didnt scrape very often. I switched to a DC JDM 4-1 replica when I got my B16B, and it didnt last but like 5 months before it was dented all to hell.
Old Nov 15, 2003 | 02:00 AM
germanEE8's Avatar
Default Re: (DigitalPunk)
Hey,
I've got a EE8 (german version of the EF8, stock with b16 engine). What header will just bold on even to the cat?-Will the 99-00 civic si do the job?
-I need 2 O2 bungs (1st and 2nd primary).Do I have to install the 2 O2 Sensors. Whats about chipping the ECU?-Dont you need the O2 Sensors anymore?
thanks for your time,
marc
Old Nov 15, 2003 | 02:59 AM
Default Re: (germanEE8)
Im not totally sure, but i think for that car you need to get a header for a '94 Del sol vtec if you want it to bolt up to the stock cat. With the stock PR3 or PW0 ecu you really need to run both O2 sensors, however with a chipped ecu, most programs only require the primary O2 sensor. Hope that helps...
Old Nov 15, 2003 | 05:19 AM
FULL-RACE EP3's Avatar
I have a Greddy SS piece on my b18c hatch. NO mods were needed. The header was origanally for a 99-00 Si. Its a nice piece, turns a nice bronze color. And bolts right up to the cat.
Old Nov 15, 2003 | 05:24 AM
germanEE8's Avatar
Default Re: (Pooptooth)
So,with a chipped ecu I only need one O2 sensor?-
Where does this sensor install?-Before the cat or do I need to drill a hole in the first primary?
What chip is good and supports only one sensor ?
Thanks,
marc
Old Nov 15, 2003 | 11:01 AM
Rywire's Avatar
I would get a dc 4-2-1(no clearence issues), and weld 2 o2 bungs in factory locations, and put a bolt in the o2 bung in the collector. Thats what I did, its great. Ryan
Old Nov 16, 2003 | 12:22 AM
germanEE8's Avatar
Default Re: (droppedcrxsi)
ok, great. whats best price for a dc 4-2-1 and where?
Are they cheaper in Japan?-Because for me theres no difference in
s/h between ordering in Japan or the US.
greetz
marc
Old Nov 16, 2003 | 01:13 AM
Bunger's Avatar
It will also depend what mount kit you're using. I believe that the hasport mount kit positions the motor farther back (good for turbos) so there should be more clearance for a larger header. Though now, most the mount kits out there now are about the same, so it may take a little cutting of the stock x-member to get some headers to fit.
I thought I remember the HCP kit positioning the motor in such a way that a Jackson supercharger was possible, but was not with the HASport kit. This was a number of years back though, so things may have changed.
Old Nov 16, 2003 | 01:40 AM
B20Monster's Avatar
Default Re: Best Fitting Header for B16 in CRX? (Bunger)
I have an AN-r header. It fits in there pretty well and the ground clearance is awesome considering the collecter is located higher up in the header. There is only one pipe going beneath the oil pan. I think it doesnt clear the a/c or p/s pump. That should be no concern if you take it out though. Heard great gains with just the installation of the header alone. I haven't broken in the motor yet, so i don't what it's potential is. Hope this helps though. Good luck!
Old Nov 16, 2003 | 04:21 AM
germanEE8's Avatar
Default Re: Best Fitting Header for B16 in CRX? (B20Monster)
Let me guess, the an-R header is way more expensive than the DC Sports ? :D
greetz
marc
Old Nov 20, 2003 | 11:10 AM
Update: Bought DC Sports Header 4-2-1, 1 piece off of Ebay for $130.00 shipped.
Old Aug 6, 2005 | 05:50 PM
M15's Avatar
M15
Default Re: (crxtreme89h)
has anyone here installed any of these headers and kept their AC?
Old Aug 6, 2005 | 07:46 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">So what do you guys think is the best fitting header? I don't want to mess with my front cross member. Nor do I want to have the header slamming every curb I go over.
Thanks in advance!
89 Si Hatch B16 w/AC Hasport mounts, OEM crossmember (soon to be Full-Race) using an old school RSR 4-2-1 Stainless header (has 2 o2 bungs)
clears with no prob and doesn't hang low, never bottomed out on Koni's & Eibach Pro-kit springs
Old Aug 12, 2005 | 01:42 PM
M15's Avatar
M15
Default Re: Best Fitting Header for B16 in CRX? (Mr. B in Az)
Which O2 bung did you have to get welded over and where can i get an RSR header from?
Old Aug 12, 2005 | 02:30 PM
b18cEF9's Avatar
Default Re: Best Fitting Header for B16 in CRX? (M15)
well if any one is interested, i had my dc sports 4-2-1 header on my 90 hatch and it took no modification to the crossmember, and its also for sale
https://honda-tech.com/zero...28723
Old Aug 12, 2005 | 03:01 PM
Ronin150's Avatar
Default Re: Best Fitting Header for B16 in CRX? (b18cEF9)
Did anyone what to switch the side their fan was on. I had to move it to the passenger side with the DC 4-2-1. Not really a problem.
Old Aug 12, 2005 | 03:56 PM
RA122324's Avatar
For starters I thought you could use the upper portion of the b16 header and your A pipe (downpipe).
Old Aug 14, 2005 | 01:09 PM
RA122324's Avatar
Can I anyone give me confirmation on this?
Old Aug 14, 2005 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 &raquo;</TD></TR><TR><TD CLASS="quote">Which O2 bung did you have to get welded over and where can i get an RSR header from?</TD></TR></TABLE>
allready came with both o2 bungs welded on (factory) and good look finding an RSR header. found mine over 3 years ago on eBay. might want to try a Greddy.
Super79Dave
10
Aug 12, 2009 06:55 PM
SmogTech01
Oct 23, 2006 07:46 PM
the jdmchop
16
Mar 10, 2004 02:36 PM
Timmayeg
May 5, 2003 08:12 PM
