jiffy lube fuel injection cleaning?
Old Nov 14, 2003 | 07:57 AM
onelowchef's Avatar
Default jiffy lube fuel injection cleaning?
has anyone ever had there car get a fuel injection cleaning from jiffy lube? if so did it work?
Old Nov 14, 2003 | 11:35 AM
King Tut33's Avatar
Default Re: jiffy lube fuel injection cleaning? (onelowchef)
I don't see why it wouldn't work. Basically they hook your fuel line up to a can of fuel injector cleaner and run the car off that can till it runs out and the car stalls out. Then they hook the fuel line back up and you are good to go. It is basically just running the car off straight fuel injector cleaner so it is real concentrated and works better than a bottle in the tank.
Old Nov 14, 2003 | 07:28 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: jiffy lube fuel injection cleaning? (King Tut33)
Actually they disconnect your brake booster line and feed it thru there. Your car cannot run on that stuff alone. That stuff is basiclly concentrated rubbing alcoho.l
Old Nov 14, 2003 | 07:40 PM
sledgehammer's Avatar
Default Re: jiffy lube fuel injection cleaning? (gunslinger)
How much is to have that done?
Mike
Old Nov 14, 2003 | 07:59 PM
mntuner2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">Actually they disconnect your brake booster line and feed it thru there.</TD></TR></TABLE>
That is actually removing the "crap" deposits on your valves, passages, intake manifold, etc. The fuel injectors are not apart of the manifold vacuum. I would say they run the "mystery fluid" through your injectors.... OR you could buy a can of Seafoam and do it yourself. Don't ask me how to use it, just read the directions on the bottle. It is a great product line. I use it at work all the time. I believe most injector cleaner products work. Just take your car on a couple full throttle romps while the cleaner is in your tank. Blah blah blah...
Old Nov 14, 2003 | 10:09 PM
JDMHN8's Avatar
Default Re: jiffy lube fuel injection cleaning? (mntuner2)
The only injector cleaner on the market that works is Chevron's Techron (or any product containing this chemical). All that other **** is just additional **** in your gas tank. That's also why you should only be using Chevron or even Shell/Texaco fuel in your car.
Old Nov 15, 2003 | 11:28 AM
King Tut33's Avatar
I have seen ones where it is a mix and you run the car directly off the can. I think I saw it on one of those car shows like Two Guys Garage on SPEED. I figured that is the way Jiffy Lube does it.
Old Nov 15, 2003 | 11:53 AM
rapid_roy's Avatar
Default Re: jiffy lube fuel injection cleaning? (JDMDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">The only injector cleaner on the market that works is Chevron's Techron (or any product containing this chemical). All that other **** is just additional **** in your gas tank. That's also why you should only be using Chevron or even Shell/Texaco fuel in your car.</TD></TR></TABLE>
Bzzzt, Seafoam.
It's better than Chevron in my experience and it's more flexible. You can put it in your oil, gas or inject it right into you throttle body. Works wonders and for really high mileage engines it really is 'magic in a can'.
I use it on my bike, car and my GF's car (185k mile Mazda 626 - runs like a top).
Cheers,
Roy
Old Nov 15, 2003 | 12:35 PM
RCautoworks's Avatar
Thanks for saving me the writing, couldn't agree with you more.
Old Nov 15, 2003 | 04:44 PM
cstem's Avatar
Default Re: jiffy lube fuel injection cleaning? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for saving me the writing, couldn't agree with you more.</TD></TR></TABLE>
Ditto.
Old Nov 15, 2003 | 08:14 PM
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">I have seen ones where it is a mix and you run the car directly off the can. I think I saw it on one of those car shows like Two Guys Garage on SPEED. I figured that is the way Jiffy Lube does it.</TD></TR></TABLE>
i saw that episode on two guys garage.
Old Nov 15, 2003 | 10:30 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">Actually they disconnect your brake booster line and feed it thru there. Your car cannot run on that stuff alone. That stuff is basiclly concentrated rubbing alcoho.l</TD></TR></TABLE>
yup thats how a buddy told me they did his...in my mind im thinking ????this has nothing to do with injector cleaning...but thats what they told him
rice_classic
21
Apr 10, 2013 09:59 PM
spun311
May 18, 2007 03:26 AM
allmtrdc4
Feb 16, 2006 09:29 PM
NsX_CrX
14
Jan 16, 2006 06:25 PM
soon2b
Apr 15, 2005 02:02 PM
