putting crx si cam in dx head
Is this just a direct boltin, I have a 93 civic dx motor(D15B7) and have a 91' crx si cam.. Also will the cam timing be off and if so can I just advance it or retard it 1 tooth.. How much of a difference over the stock D15B7 cam will it make.. Thanks
it's the same, no adjustments needed, you may want to buy some new Si springs because the B7s are only good to about 5500rpm with the Si cam. I'm runing a B1 with a B7 head and Si cam and no problems
edit: this cam will pull hard untill 6800rpm and then the power fades out... but your car can only go 6500 with stock rev limiter so no worrys their
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout »</TD></TR><TR><TD CLASS="quote">it's the same, no adjustments needed, you may want to buy some new Si springs because the B7s are only good to about 5500rpm with the Si cam. I'm runing a B1 with a B7 head and Si cam and no problems
edit: this cam will pull hard untill 6800rpm and then the power fades out... but your car can only go 6500 with stock rev limiter so no worrys their</TD></TR></TABLE>
Ahh.. So it does make a good difference between the dx and the si cam.. Ill have to look at the junkyard this weekend and get the cam the springs..
Sheep
29
Apr 2, 2007 11:01 PM
crex23
18
May 13, 2005 07:49 PM
1CiViC1
Jul 17, 2003 01:07 AM
BoostedD15B7
Apr 28, 2003 10:29 PM
