Will a GSR or ITR throttle body fit on a LS?
Old Nov 14, 2003 | 07:20 AM
JDubya's Avatar
Default Will a GSR or ITR throttle body fit on a LS?
Yes? No? how bout if I got a Skunk2 manifold (would that even make a difference?)
Old Nov 14, 2003 | 07:24 AM
player2z's Avatar
Default Re: Will a GSR or ITR throttle body fit on a LS? (ALL MOTOR LS)
my friend actually made a ls fit on a gsr it fit somehow! he had a lsvtec , and he made it fit, use the right gasket, i think
Old Nov 15, 2003 | 02:02 PM
JDubya's Avatar
Default Re: Will a GSR or ITR throttle body fit on a LS? (player2z)
anyone else?
Old Nov 15, 2003 | 02:09 PM
JDM_Honda_Fiend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">Yes? No? how bout if I got a Skunk2 manifold (would that even make a difference?)</TD></TR></TABLE>
Yes it will fit depending on your generation of your teg. Generally the only difference is the map sensor placement on the TB. Of course your best bet would to go with a bored out TB and a skunk manifold which will give you more airflow but the gains between a bored out TB and an ITR TB isn't much. So save some money and get your TB bored out instead of getting a new one. I've seen an ITR TB produce no HP gain except for 1LB of Torque when compared to an bored out TB.
Cheers
Old Nov 15, 2003 | 02:18 PM
JDubya's Avatar
Default Re: Will a GSR or ITR throttle body fit on a LS? (JDM_Honda_Fiend)
Well I will be boosted soon if that'll make a difference. So i'm thinkin a bored out GSR throttle body + skunk2 or JG manifold will help. What all has to be done to fit the throttle body on it? throttle cable bracket, what?
Old Nov 18, 2003 | 08:19 AM
JDubya's Avatar
bump it up
Old Nov 18, 2003 | 08:51 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">Well I will be boosted soon if that'll make a difference. So i'm thinkin a bored out GSR throttle body + skunk2 or JG manifold will help. What all has to be done to fit the throttle body on it? throttle cable bracket, what?</TD></TR></TABLE>
I'm pretty sure the B20 throttle body is larger diameter than the LS... I have heard of people putting a Skunk2 IM and B20 TB for good gains... However, I'm not exactly sure what the difference in diameter is between the two... HTH...
Old Nov 18, 2003 | 10:25 AM
JDubya's Avatar
Default Re: Will a GSR or ITR throttle body fit on a LS? (4U2NV)
Does anyone know the inlet mm of a LS Skunk2 manifold?
Old Nov 19, 2003 | 05:21 AM
JDubya's Avatar
Will ITR TB fit? What needs to be done to make it?
Old Nov 20, 2003 | 04:22 AM
JDubya's Avatar
I guess I'm better off buying a larger aftermarket TB...
Old Nov 25, 2003 | 06:06 PM
rlstabber's Avatar
skunk2 IM has a 64mm plenum. gsr will fit on a b18 or b20 IM, but you have to run the throttle cable from the other side.
Old Dec 1, 2003 | 03:52 PM
htownteg's Avatar
Default Re: (rlstabber-eg)
i think thats the same with ITR, you have to reroute the throttle cable too
Old Dec 1, 2003 | 04:04 PM
Mr. Softee's Avatar
Default Re: (htownteg)
i have a gsr throttle body / cable on my LS.
sam
Old Aug 21, 2013 | 09:11 AM
topasnajames's Avatar
I believe its 70mm, earlier this morning I was checking my tps and decided to see if the TB opening to the IM was fitting perfectly of if I would have to bore it out a bit and it felt as if it was a direct perfect bore.
Old Aug 21, 2013 | 09:30 AM
Ok well I just got off the phone with SKUNK2 and the guy said that this year they started manufacturing the bore of TB at 70mm
Old Aug 21, 2013 | 01:05 PM
PphamEK's Avatar
yes
Old Aug 22, 2013 | 01:38 PM
96cxt's Avatar
ITR will fit. Skunk2 alpha 70mm will also fit
watisjdm
17
Apr 15, 2007 07:06 PM
d_mina
Aug 7, 2004 09:50 AM
htownteg
Nov 27, 2003 09:59 AM
JohnnysEG
May 9, 2003 06:33 PM
