any 5th genth accord broken timing belt here?
think of the car is in wot, the two intake valves are wide open, snap&(*^(%^(#& the timing belt's done
the pistons are driven by the crankshalf hit the two valve, bending both of them and giving a good scraping to the piston surface, the rod slammed to the wall.
cool sh-t huh? honda ohc=interference engine
unless you drive a old skool car with L or T head motor
yeah i work at the dealership......just recently i worked on a 94 civic w/ 200k miles on it.......it came in w/ a no start and die on freeway.......
his timing belt broke, so i put new one in......line up all the mark......start it up.....run fine.....
shut it down. check compression.......that engine is good.......god damn lucky.....
because of dat experienced that's why i want to know if any other lucky owner...
sorry about my bad gramma, and over lap sentence.. hehehe
One thing that makes a huge difference in whether or not valves get slapped is manual or automatic tranny. I've only seen one auto car that bent valves when his belt broke and he said he was at about 5k rpm when it happened. I've seen quite a few manuals that have broken belts with no damage. These motors are interference motors, but with the exception of a couple Prel. setups they are not extreme tolerance motors. Our shops usual is to throw a belt on it and see if it runs. Most fire right up with no ill affects.
AccordInTheMaking
Feb 11, 2010 06:08 AM
