Koni Adapters for GC's still available? where can i buy
Old Nov 13, 2003 | 10:10 PM
sjteg's Avatar
Default Koni Adapters for GC's still available? where can i buy
i'm looking to buy a set of gc's off of a fellow member but they're the normal ones. Are the adapters still available from gc or do i have to buy the sleeves?
Old Nov 13, 2003 | 11:00 PM
sjteg's Avatar
Default Re: Koni Adapters for GC's still available? where can i buy (sjteg)
ttt
Old Nov 14, 2003 | 11:25 AM
sjteg's Avatar
bump
Old Nov 14, 2003 | 11:28 AM
P1mpSlap's Avatar
Ground Control's website
Old Nov 14, 2003 | 12:03 PM
sjteg's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Ground Control's website </TD></TR></TABLE>
a simple answer would do without the hammer.
Old Nov 18, 2003 | 02:26 PM
fishnfst's Avatar
You have to buy the complete sleeve.
Old Nov 18, 2003 | 03:02 PM
sjteg's Avatar
Default Re: (fishnfst)
i think i'll just get some koni specific ones. The sleeves are expensive
Old Nov 18, 2003 | 03:07 PM
tgrace's Avatar
Default Re: (sjteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjteg &raquo;</TD></TR><TR><TD CLASS="quote">i think i'll just get some koni specific ones. The sleeves are expensive</TD></TR></TABLE>
That would be your best bet anyway. It would be much eaiser just to buy the correct ones up front instead of rigging something up.
Old Nov 18, 2003 | 04:51 PM
Eviloliv3's Avatar
the koni specific ones are the sleeves...
in the bottom of the sleeve there is a little adapter that is fitted into the sleeve to allow the sleeve to sit on the perch on the konis
Old Nov 18, 2003 | 04:59 PM
sjteg's Avatar
Default Re: (Eviloliv3)
where's the cheapest place to get them at?
Old Nov 23, 2003 | 07:04 PM
fishnfst's Avatar
You should be able to get them for around 300 for the Koni GC set up. I think just the sleeves is like $100. Much cheaper to just get the whole thing. The springs are 59 a piece a 100 for the sleeves and then 16 a piece for the perches. You are much better off buying the proper kit.
importdude2000
Suspension & Brakes
Jun 17, 2007 07:28 AM
ophdehEEzY
Nov 29, 2005 10:08 PM
11psiTurboSI
Jun 5, 2004 05:08 AM
One Bad GeeSeeR
May 4, 2004 08:38 PM
