with 12:1 compression would
1mm OS valves and radius valve job be worth it. Since the car's been apart, i've had the head milled .040" I'm trying to pick up another 10 - 15 at the wheels when i reassemble it. Thoughts comments?
I personally haven't seen gains before with O/S valves on Honda motors before. In a specific high output motor tough to say. But your everyday 180-220whp N/A B-Series motors, hasn't show much if any gains.
That's not going to happen, it isn't easy to make 10-15whp... If you're naturally aspirated you first need compression then a good combo of headwork and cams... Then you can expect some gains... Good Luck anywho... Peace
castanagajt
16
Oct 5, 2009 04:39 PM
PirateMcFred
Jun 17, 2004 09:23 PM
