81.5mm JE Pistons, High Compression
Pistons are brand new, never installed. They are balanced, and include wrist pins and wire locks. Also come with rings.
Need to sell ASAP. Nopi's price on these is $550.
I'm selling these for $525.
I need some but not trying to spend $450 + on some pistons cause even the b20/vtec JE's sell for only $483 brand new from NOPI. Maybe if you keep comming down on the $ you could get rid of them..just my 2cents
what the hell....?
from nopi's ecat.... i smell fish..?
133+2499 JE/SRP Piston Set of 4 - Si B16A/B16A2/B16A3 1.6L DOHC VTEC - Bore 3.189 - Stroke 3.031 - Rod Length 5.29 - Grams 290 - Dome Volume +5.7cc - Compression Height 1.181 - CC's 42.7 - Compression Ratio 10.5:1 - use ring set 135+3029 $373.94
133+2500 JE/SRP Piston Set of 4 - Si B16A/B16A2/B16A3 1.6L DOHC VTEC - Bore 3.199 - Stroke 3.031 - Rod Length 5.29 - Grams 294 - Dome Volume +5.7cc - Compression Height 1.181 - CC's 42.7 - Compression Ratio 10.5:1 - use ring set 135+3030 $373.94
133+2504 JE/SRP Piston Set of 4 - Si B16A/B16A2/B16A3 1.6L DOHC VTEC - Bore 3.209 - Stroke 3.031 - Rod Length 5.29 - Grams 277 - Dish Volume -2.2cc - Compression Height 1.181 - CC's 42.7 - Compression Ratio 9.0:1 - use ring set 135+3031 $373.94 - Set View 133+2501 JE/SRP Piston Set of 4 - Si B16A/B16A2/B16A3 1.6L DOHC VTEC - Bore 3.209 - Stroke 3.031 - Rod Length 5.29 - Grams 296 - Dome Volume +5.7cc - Compression Height 1.181 - CC's 42.7 - Compression Ratio 10.5:1 - use ring set 135+3031 $373.94
is that with rings nopi price?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisir19 »</TD></TR><TR><TD CLASS="quote">what the hell....?
those are 10.5:1 compression pistons for b16a. he's selling 12.5:1 pistons
