Any FI guys with a lightened flywheel?
Old Sep 10, 2001 | 07:35 PM
nutsack's Avatar
Default Any FI guys with a lightened flywheel?
just wondering if its worth it when you have FI, i've been thinking of just doing a 9lb flywheel whenever i get around to doing my clutch.
Old Sep 13, 2001 | 07:52 PM
nutsack's Avatar
Default Re: Any FI guys with a lightened flywheel? (*******)
wow, no replies.
Old Sep 13, 2001 | 07:59 PM
dustin's Avatar
It is worth it, I have an ITR flywheel and i wish I had about an 8lb flywheel. Next time I change the clutch, I'll put one in
Dustin
Old Sep 14, 2001 | 06:04 AM
BlwnBlue's Avatar
Default Re: Any FI guys with a lightened flywheel? (dustin)
I have a 9lb toda flywheel and it was one of the best choices I could've made!
I recommend a lightened flywheel!
Old Sep 14, 2001 | 06:16 AM
b18bturbo's Avatar
Default Re: Any FI guys with a lightened flywheel? (BlwnBlue)
i use a special carbon carbon flywheel that is like 6lbs in the race car. Revs like mad bitch but overall i havehad no prblems just gotta get used to keepin the revs up.
Old Sep 14, 2001 | 06:20 AM
civicgsr's Avatar
My brother is running a lightened flywheel (11lb) in his turbo GSR. Bottom end response feels much better. It's definitely worth it.
Old Sep 14, 2001 | 07:15 AM
JM Performance's Avatar
dustin: what kind of difference did you feel w/ the ITR flywheel over stock. I just bought one and am wondering how it will feel.
Old Sep 14, 2001 | 07:35 AM
dustin's Avatar
Default Re: Any FI guys with a lightened flywheel? (00SilverLS)
There is a noticeable difference w/ the ITR flywheel. The revs drop a bit faster between shifts and make the car easier to drive. I still wish it was lighter though
Dustin
Old Sep 18, 2001 | 12:31 PM
ttt : wanna hear more replies.
Old Sep 18, 2001 | 01:33 PM
turbod97ex's Avatar
New User
I have the Clutch Masters lightened flywheel with a stage 3 clutch. I got the clutch before I turbo'd and it did help the bottom end. I don't race mine much since it is my only car and can't afford for something to go wrong so I really can't vouch for how hard it is to keep the revs up. It stands to logic that it would as it has less enertia, conversely, since it is lighter and doesn't require as much energy to get the revs up . The CM fly is nice because the friction point is a replaceable ring. A lot of flywheels come like that.
Old Sep 18, 2001 | 08:14 PM
smoothludey2's Avatar
New User
Default Re: Any FI guys with a lightened flywheel? (turbod97ex)
what do you mean replaceable ring? how is that an advantage?
Old Sep 18, 2001 | 09:11 PM
turbod97ex's Avatar
New User
Default Re: Any FI guys with a lightened flywheel? (smoothludey2)
On your flywheel, there is a surface area that mates with the clutch disk. This area on a flywheel without the replaceable ring would need to be machined if you abuse your clutch (racing) or if you dont replace your clutch when the friction material is gone. Much like what happens when you don't replace brake pads when you should have. If machining doesn't correct it, you replace the flywheel.
In the case of a flywheel with replaceable friction ring, you replace the ring.
Old Sep 19, 2001 | 12:32 AM
liam821's Avatar
i have a JUN lightweight flywheel on my d16z6. They made two types, a lightweight and a super lightweight. Jun told me i wanted the lightweight for a turbo car.
I think its 9 or 10 pounds.
But its awesome...revs soo fast!! I love it and if i go b-series i plan on getting another JUN.
liam
Old Sep 19, 2001 | 04:41 AM
4dGSR at work's Avatar
Default Re: Any FI guys with a lightened flywheel? (liam821)
i hear jun and exedy fly's are the same material so...
and they are both about 10lbs.
but where is the best deal...i am looking to go lighter too
Old Sep 19, 2001 | 05:22 AM
austrian type-R's Avatar
Default Re: Any FI guys with a lightened flywheel? (4dGSR at work)
I´ll buy me a Fidenza flywheel for my R when I´m at the SEMA in Las Vegas. I have only heard good things about it. It is not too light and not to heavy. I think it is rated at +/- 10lbs
Old Oct 10, 2001 | 05:33 PM
jamal-188's Avatar
Default Re: Any FI guys with a lightened flywheel? (austrian ITR)
Do you think the clutch master 7.5 aluminum would be safe to use w/ a turbo setup? Should I get a scattersheild or go with something like a chrom moly that might be stronger?
Old Oct 10, 2001 | 05:49 PM
dustin's Avatar
What days are you going to the show? Mike and I are going
Dustin
brianmcivics
12
Nov 23, 2007 02:17 PM
immalooser
Oct 18, 2005 08:08 PM
twitchm80
Oct 4, 2002 09:17 AM
