crx with b16 without changing hubs
Old Nov 13, 2003 | 04:33 PM
ironchef25's Avatar
Default crx with b16 without changing hubs
ok. i just got off the phone with my local performance shop. going to swap the crx with a b16. i asked them if they are going to change the hubs and the breaks they said it was not neccessary. only the axles? is this true???ive had this conception that inorder to fit the axle neccesary for a b16 swap is to change the hub. or is there a way that you only change the axle but not the hub for a b16swap.oh by the way i have a 88crx hf.
Old Nov 13, 2003 | 04:35 PM
EL Vap133's Avatar
Default Re: crx with b16 without changing hubs (ironchef25)
If it has stock HF hubs then it is required to change the hubs from what I know.
Old Nov 13, 2003 | 04:43 PM
ironchef25's Avatar
Default Re: crx with b16 without changing hubs (EL Vap133)
yah thats what i thought too. and if you change the hubs. your gonna need to change your breaks too right?
Old Nov 13, 2003 | 04:55 PM
bluecrxsi's Avatar
i know in an si you just remove the dust cap from the inside of the hub and your teg axles will fit perfect, but cant tell you about a dx. mine is an si,if your hub is the same as mine you're good to go! mine popped right in!
Old Nov 13, 2003 | 04:58 PM
ironchef25's Avatar
Default Re: crx with b16 without changing hubs (bluecrxsi)
i have crx 88fh.
Old Nov 13, 2003 | 05:31 PM
90crxb16a's Avatar
DX has same size hubs as SI. Just remove dust cover and axles will work fine.
Old Nov 13, 2003 | 06:44 PM
ironchef25's Avatar
Default Re: (90crxb16a)
[QUOTE=90crxb16a]DX has same size hubs as SI. Just remove dust cover and axles will work fine.
yah so does this mean its also for the hf?
Old Nov 13, 2003 | 07:12 PM
BIG RICH's Avatar
Default Re: (ironchef25)
no. for the HF, you have to get the hubs from a Si or a DX.
Old Nov 13, 2003 | 09:13 PM
c jackson's Avatar
threes
Default Re: (BIG RICH)
go to hasport.com they have a whole writeup on axles and fitment with the different years.
Old Nov 13, 2003 | 10:09 PM
KoRE's Avatar
Default Re: (c jackson)
Yep You need new hubs
HF(CRX) and STD(Civic) need new hubs when doin a b Series
Check http://www.Car-Parts.com (thanks El Vap )
for my both hub assemblies for $100 shipped
Old Nov 13, 2003 | 10:36 PM
Lucifer6i9's Avatar
Default Re: (KoRE)
ok maybe you really dont need to change the hubs if you do some axel surgery u can just swap out tha end part of tha axel that goes into tha spindle on tha hf hub. just an idea what ya guys think???
Old Nov 14, 2003 | 06:28 AM
andrew dc's Avatar
Default Re: (Lucifer6i9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucifer6i9 &raquo;</TD></TR><TR><TD CLASS="quote">ok maybe you really dont need to change the hubs if you do some axel surgery u can just swap out tha end part of tha axel that goes into tha spindle on tha hf hub. just an idea what ya guys think???</TD></TR></TABLE>
yes you can, but why go thought the trouble... by getting new hubs you will also up grade your brakes from a 8.X" to 9.5". since you will be adding more hp and since honda love to utilize the front brakes so much, why not get the bigger brakes!?
Old Nov 14, 2003 | 09:05 AM
virginia_dude's Avatar
replace the hubs, HF has wimps axeles and brakes, do yourself a favor and upgrade them too.
Old Nov 14, 2003 | 10:22 AM
EL Vap133's Avatar
Default Re: (KoRE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE &raquo;</TD></TR><TR><TD CLASS="quote"> (thanks El Vap )</TD></TR></TABLE>
No problem bro!
Old Nov 15, 2003 | 09:23 PM
Lucifer6i9's Avatar
Default Re: (andrew ef)
i understand that it would b dumb , but i believe tha original question was " can you use hf axels?" i was just showing him that it can be done.
dohc_87hatch
Nov 12, 2009 10:01 AM
xtokex
Sep 22, 2007 04:15 AM
mikester1222
Jan 22, 2007 06:11 PM
hotrodlincoln
Oct 29, 2006 11:39 AM
crix180
Jun 29, 2003 12:55 PM
