FS: B16a mapped PM6 ECU, B-series AEM Cam Gears, B16 IM + TB *CHEAP*
Old Nov 13, 2003 | 02:54 PM
Hybridize's Avatar
Default FS: B16a mapped PM6 ECU, B-series AEM Cam Gears, B16 IM + TB *CHEAP*
Like the title says, these items are for sale.
1. B16a mapped PM6 ECU. This is a regular PM6 ecu reprogrammed to run a B16 engine. Reprogramming was done by Pro-Speed Performance. ECU works and looks great. *CHEAP* $85 shipped! *note* This ECU, like other reprogrammed NON-VTEC ECUs, does not have provisions to activate VTEC.
2. AEM cam gears for a B series engine, blue color. One(1) of the gears is damaged, but would probably still work fine. It appears that at one time the wrong woodruff key was used allowing this gear to spin on the camshaft, causing the inside area of the gear to get "reemed" out a little bit. I installed the gear on another cam and it seemed to be fine, it went on straight and did'nt wobble or move after being torqued. I would probably use them myself, but I have a different set of gears on the way. Price is $35 shipped, for the damaged gear. $70 shipped for the undamaged gear. $95 shipped, for both gears.
Good price for someone that doesn't mind what appears to be cosmetic damage.
3. B16a Intake manifold w/ fuel rail. Looks good. $65 OBO shipped.
4. B16a throttle body. TPS is broken, other then that it looks good. $35 OBO shipped.
Both 3 and 4 for $80 shipped.
PICS AVAILABLE ON REQUEST. Please IM me with your E-mail addy if there's anything you want pics off.
My vouch thread: https://honda-tech.com/zerothread?id=661592
Thanks for looking!
Old Nov 14, 2003 | 06:38 PM
Hybridize's Avatar
Bump.
Mac101989
Jun 7, 2008 06:44 PM
112480
Jan 20, 2007 03:24 AM
Adam.
May 21, 2005 12:57 PM
