Camber kit front? rear? or both?
Old Nov 13, 2003 | 01:27 PM
brian2903's Avatar
Default Camber kit front? rear? or both?
I heard some people said most of the 90-97 Accord doesn't need camber kit for rear, but only front camber kit is enough. Is that true? and which brand is good?
Thanks.
Old Nov 13, 2003 | 04:04 PM
brian2903's Avatar
Default Re: Camber kit front? rear? or both? (brian2903)
any one??
Old Nov 13, 2003 | 04:13 PM
RastaGt1's Avatar
You could probably get away with just shimming it to the correct alignment settings, but if you want to be sure I would grab a kit. Don't forget though, you will need a front camber kit and a rear upper cross bar. Check out http://www.spcperformance.com/....html
Old Nov 13, 2003 | 05:14 PM
Steve04SVT's Avatar
Default Re: Camber kit front? rear? or both? (RastaGt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RastaGt1 &raquo;</TD></TR><TR><TD CLASS="quote">You could probably get away with just shimming it to the correct alignment settings, but if you want to be sure I would grab a kit. Don't forget though, you will need a front camber kit and a rear upper cross bar.</TD></TR></TABLE>
That's what I did. Used some washers I had lying around in the garage.
Old Nov 13, 2003 | 08:00 PM
aaaallll04's Avatar
Default Re: Camber kit front? rear? or both? (Steve00GSR)
haha washers will work just fine, but you will probably only need them in the rear
Old Nov 13, 2003 | 10:10 PM
iam7head's Avatar
Default Re: Camber kit front? rear? or both? (aaaallll04)
on 6th gen? i dont think so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaaallll04 &raquo;</TD></TR><TR><TD CLASS="quote">haha washers will work just fine, but you will probably only need them in the rear</TD></TR></TABLE>
Old Nov 13, 2003 | 10:25 PM
im_the_teacher's Avatar
Default Re: Camber kit front? rear? or both? (iam7head)
you guys know where you can get front camber kit for cheap?
this is where i get mind front camber kit for 70$, i dun know what the price rite now,,,,,probably increase cuz they realize that there a market for it.
http://www.streamlinemotoring.com
and the rear, like many have said, just use couple washer, but note: when u fix the rear, your car will raise a lil and the gap may increase........(thats what happen to my 97 accord.)
Old Nov 13, 2003 | 10:28 PM
iam7head's Avatar
Default Re: Camber kit front? rear? or both? (im_the_teacher)
here we go
no .orig.jpg in the end
Old Nov 13, 2003 | 10:29 PM
hey "iam7head" why u repost my pic? oh never mind u were try to fix it.........hehe my bad, thanks dude
Old Nov 13, 2003 | 10:35 PM
w/ 3inch drops, here how the car look before the camber kit......and bad aligment
matt94z
19
Aug 8, 2008 06:14 AM
Mycull
Honda Civic (2001 - 2005)
Jun 6, 2007 02:47 PM
guero2craze
Suspension & Brakes
May 1, 2007 05:58 PM
ZTYPE_S
Mar 21, 2004 06:14 PM
PnX-R
Apr 28, 2002 03:37 PM
