skunk2 stage 2 head work, now no vtec?
Old Nov 13, 2003 | 11:51 AM
HatchBox's Avatar
Skoobie no more...
Default skunk2 stage 2 head work, now no vtec?
my friend just had his head all rebuilt, he put in
skunk 2 stage 2
cams
cam gears
valves
retainers
intake manifold
he also added a aem fuel rail and regulater
he is currently running on the VAFC II
*problem*
he got the car back all rebuilt last night (11/11) the shop he had do it let the car run for aprox 30 min. then he drove it home about 50 miles or so, now he didnt really go hard on it untill he got it almost home, then he let it go past vtec, but he said that it doesnt seem to engage, the VAFC says its kickin on but it doenst pull or sound like its getting vtec.
*cliffnotes if u were to lazy to read
friend got skunk 2 stage 2 head rebuild...now it seems to not hit vtec.
Old Nov 13, 2003 | 12:04 PM
Big Poppa Pump
Guest
Posts: n/a
Skunk2 Stage2 cams on stock compression is a No, No first of all. It also sound like your friend skipped out on the tunning which is also a big NO, NO.
Old Nov 13, 2003 | 12:08 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Big Poppa Pump)
please explain more
Old Nov 13, 2003 | 05:42 PM
michael O's Avatar
damn how many threads about this you gonna make?
Old Nov 13, 2003 | 06:15 PM
CHRIS 1.8's Avatar
Default Re: skunk2 stage 2 head work, now no vtec? (ind3ciso)
Does your friend hear a change in exhaust noise when engaging into VTEC?
Also, you need to dyno tune.
Old Nov 13, 2003 | 07:11 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">damn how many threads about this you gonna make?</TD></TR></TABLE>
untill i find a straight up answer...i need to find out ASAP it is his Daily driver and yeah we dont want it blowing up or anything so im just trying to find out quick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHRIS 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">Does your friend hear a change in exhaust noise when engaging into VTEC?
Also, you need to dyno tune.</TD></TR></TABLE>
nope no exhaust change...
Old Nov 13, 2003 | 08:33 PM
Triple T's Avatar
Default Re: (ind3ciso)
Whats his compression? Skunk stage 2s love compression... I would get it on a dyno asap. What ecu is he running and did they put the vtec solenoid back on ? just a thought.
Old Nov 13, 2003 | 08:41 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Triple T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Triple T &raquo;</TD></TR><TR><TD CLASS="quote">Whats his compression? Skunk stage 2s love compression... I would get it on a dyno asap. What ecu is he running and did they put the vtec solenoid back on ? just a thought.</TD></TR></TABLE>
he is running stock compression, i dont think he has checked it. he says he wants to upgrade to ctr pistons and gsr rods...that should up the compression right?
Is this the way to go? or shoud he go aftermarket?
he is running the stock ecu. everything is hooked up.
Old Nov 13, 2003 | 10:13 PM
Triple T's Avatar
Hmmm, hes definitely going to need more compression in order to get the most out of those cams, i would say just throw it on the dyno and see whats up. He should up the compression though asap if he wants to see the gains from those cams. A chipped ecu would also help.
importracer0008
Oct 31, 2007 12:17 PM
blowme
Jun 28, 2005 05:39 PM
AllMoToRB18c
17
Mar 14, 2005 10:14 AM
HatchBox
Nov 13, 2003 04:39 PM
HatchBox
Nov 12, 2003 02:26 PM
