ek side skirts on ef???
Old Nov 13, 2003 | 10:28 AM
delux247's Avatar
Default ek side skirts on ef???
I heard a rumor that ek side skirts fit or can be made to fit an ef. Fact or Fiction?....any pics?
Old Nov 13, 2003 | 10:34 AM
SpyderZEX's Avatar
Default Re: ek side skirts on ef??? (egcivicturbo)
I don't have any pics, but given the time, money, and dedication, you can make almost anything fit on anything. I'd imagine that if you were to cut the side skirts you could make them the proper length and then use bondo to fill the seam. Just a quick idea...
Old Nov 13, 2003 | 11:46 AM
delux247's Avatar
Default Re: ek side skirts on ef??? (SpyderZEX)
well i just heard that this has been done before and im interested in doing it i just think my EF just looks plain with out them
Old Nov 13, 2003 | 12:23 PM
SpyderZEX's Avatar
That's cool.... If you want to do this.
This is how I would do it.
1. Measure the length of the chassis that is in between the wheels.
2. Measure the lenght of the side skirt that you are using.
3. Cut the side skirt at a point where not too many surface changes are happening. ( this will make it easier when you have to blend the bondo in)
4. Make new holes to screw the side skirts to the bottom of the car.
5. secure the two pieces so that the front and the back are flush with the wheel wells.
6. Apply the bondo. Allow addquite time to harden.
7. Take the sideskirt off of the car.
8. Sand down the bondo and try your best to maintain the contours of the surface.
9. Clean, primer, and paint your skirts with the color of your choice.
10. Put them on the car.
This is quick and it should work. The only problem that you should have will be lining up the clips that hold the side skirts on. However, with a little creativity you should be able to work things out. Good Luck! If you try it let me know how it turns out....
Old Nov 13, 2003 | 02:22 PM
NA_crix's Avatar
Here's a couple pics....
not the best, but hope they help.
Old Nov 13, 2003 | 02:37 PM
bryant's Avatar
Default Re: ek side skirts on ef??? (NA_crix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_crix &raquo;</TD></TR><TR><TD CLASS="quote">Here's a couple pics....
not the best, but hope they help.</TD></TR></TABLE>
Gotta take .orig off for them to work
Old Nov 13, 2003 | 03:01 PM
I LUV WRX's Avatar
Aliens exist.Fact or Fiction?
Heres an idea...Go try it!
Old Nov 13, 2003 | 03:44 PM
Teknic73's Avatar
Default Re: ek side skirts on ef??? (projectmiata)
i believe JDMEF9SiRin619 used EG sideskirts which look even better, correct me if im wrong.
Old Nov 13, 2003 | 04:36 PM
delux247's Avatar
Default Re: ek side skirts on ef??? (Teknic73)
yeah i definatly like the eg (if they are EG) side skirts
Old Nov 13, 2003 | 05:31 PM
88CiViC_DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teknic73 &raquo;</TD></TR><TR><TD CLASS="quote">i believe JDMEF9SiRin619 used EG sideskirts which look even better, correct me if im wrong. </TD></TR></TABLE>
i thought those were the ef9 jdm sideskirts...hard to find, but look like the 5th gen sides.
Old Nov 13, 2003 | 08:23 PM
delux247's Avatar
Default Re: ek side skirts on ef??? (88CiViC_DX)
thats also what i was told but who knows
Old Nov 13, 2003 | 08:40 PM
Miracle_X_Bar's Avatar
i don't know the guy...but 98% sure that they are stock "jdm" side skirts!
Old Nov 14, 2003 | 05:28 AM
delux247's Avatar
Default Re: ek side skirts on ef??? (Miracle_X_Bar)
good times
Old Nov 14, 2003 | 09:06 AM
LoSt is BlaCk's Avatar
NO, ryan is serious about making sure everything on that car are "real jdm"! you guys better not let him hear about this! lol!
me in the other hand, i'm all about the eg skirts!
Old Nov 14, 2003 | 09:24 AM
eccentric.ek's Avatar
Default Re: ek side skirts on ef??? (Chpt1onBOOST [DMV])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chpt1onBOOST [DMV &raquo;</TD></TR><TR><TD CLASS="quote">]
me in the other hand, i'm all about the eg skirts!</TD></TR></TABLE>
yea there the ef9 skirts,..
Old Nov 14, 2003 | 12:26 PM
delux247's Avatar
Default Re: ek side skirts on ef??? (.redusdmhb.[DMV])
cool well just as long as were all on the same page
efcrew
Jul 18, 2007 04:25 PM
B16EJ
Mar 19, 2005 01:34 PM
McD
Jan 30, 2003 02:52 PM
McD
Jan 30, 2003 01:43 PM
