would DC2 coilovers fit an ek???
Old Nov 13, 2003 | 09:56 AM
todapower's Avatar
Default would DC2 coilovers fit an ek???
i know dc2 coilovers fit an eg but i have a buyer with an ek that is interested in my dc2 tein ss coilovers. they wont fit, right???
Old Nov 13, 2003 | 10:31 AM
I Have an STD's Avatar
wrenchin'
they fit. just put suspension from my girlfriends dels sol (eg) inter her 96 civic. fits fine
Brett
Old Nov 13, 2003 | 10:34 AM
VTECorona's Avatar
Default Re: (AngryBlackSedan)
They will fit but I think there is something about them that isn't right for them to be interchangeable. My tokico shocks and coilovers are compatible for a 88-91 (i think) civic and 94-01 integra
Old Nov 14, 2003 | 10:22 AM
bogus_ek's Avatar
Default Re: (VTECorona)
anytime you're using dc2 coilovers on 92-00 civic or 94-up integra, you have to replace the lower control arms with the ones of the type r.
Old Nov 14, 2003 | 10:51 AM
thegrinch's Avatar
Default Re: (bogus)
not true that only applies to the "r"
Old Nov 14, 2003 | 11:00 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: (bogus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus &raquo;</TD></TR><TR><TD CLASS="quote">anytime you're using dc2 coilovers on 92-00 civic or 94-up integra, you have to replace the lower control arms with the ones of the type r. </TD></TR></TABLE>
Doesn't apply to all coilovers.
Correct me if I'm wrong, but aern't the EK and dc2/eg/ITR LCAs a different length from one another? Which would make it impossible to swap them?
You may need the entire GSR, ITR, EG rear assembly.
Not 100% sure.
Old Nov 14, 2003 | 02:03 PM
todapower's Avatar
Default Re: (bogus)
dc2 is any 94-2001 integra, dc2 is not just a type r.
BIGGIDYBOB's Avatar
Default Re: (integra707)
Not sure if this helps but my ek got totalled and so i bought a DC4. I swapped the rear GroundControls/tokicos onto the integra - no problem. But i think w/ the fronts, the spring rate is different because of the b-series engine weighing more than a D-series (correct me if i'm wrong). I hope the guy w/ the ek has a B-series under the hood
Old Nov 14, 2003 | 02:08 PM
todapower's Avatar
Default Re: (BIGGIDYBOB)
yes he does. i should hope he has atleast a b series if hes investing in teins...
Old Nov 14, 2003 | 02:55 PM
VTECorona's Avatar
Default Re: (todapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todapower &raquo;</TD></TR><TR><TD CLASS="quote">
dc2 is any 94-2001 integra, dc2 is not just a type r.</TD></TR></TABLE>
DB7: 4dr B18B
DB8: 4dr B18C
DC4: 2dr B18B
DC2: 2dr B18C
FYI, a DC2 is any B18C equipped 2 door integra. 4 door integras are DB
Modified by VTECorona at 7:53 PM 11/14/2003
chockz
Suspension & Brakes
Feb 20, 2008 08:47 PM
AnclyT
Feb 27, 2006 08:25 AM
Anyotherone
Oct 13, 2003 01:25 PM
ichibano
12
Jan 15, 2003 11:07 PM
