Redline of H22
I was wondering what's the redline of the JDM H22 and the USDM H22? I have an JDM H22 and somehow it revs past 7900 and I don't know why. Doesn't the JDM p13 ecu have a rev limiter? Thanks in advance.
it revs that high because that is the inaccurate RPM that is displayed by your guage cluster
the redline is 7500 and fuel is around 7600
the factory tach reads about 3-400rpms too high at those RPMs
I've been told that the USDM ecu does not have a rev limiter. That's why I am worried that the shop has switched out my ecu with a USDM H22 one. Isn't the USDM H22 redline at a different point from the JDM H22?
7600 is about the fuel cut range, you would want to shift before that, like already stated H22's quit making power around the 6800 range with out head work. Its pointless to rev that high, its not like a GSR motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 »</TD></TR><TR><TD CLASS="quote">But if a person with a H22 shifts at 6800, wouldnt it make the car slower because it dips slightly out of vtec when shifting to the next gear? </TD></TR></TABLE>
yes, from 1-2 i shift at about 7500 on stock accord tach(so about 7100) to keep in vtec for 2nd and from 2-3 i little lower and i stay in vtec, after 2-3 if you're at 7000+ then you will stay in vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">
yes, from 1-2 i shift at about 7500 on stock accord tach(so about 7100) to keep in vtec for 2nd and from 2-3 i little lower and i stay in vtec, after 2-3 if you're at 7000+ then you will stay in vtec</TD></TR></TABLE>
yea, that is right. I was just saying there is no real need to go up to anything like 8k, or past 7.5k for that matter. Even thought the car quits making power that high, i still get my quickest quater mile time by taking it up just before the redline and shifting and thats even with a v-afc where i can set my vtec engagement point
according to my VAFC fuel cut with a JDM p13 is ~7650 and i believe that is the same for USDM. you may see 8k on your tach, but that is not 100% accurate. hell i do and that only ~7,400-7,500 for me.
hybrid88hatch
Nov 25, 2003 03:03 PM
