act 4puck unsprung
Old Sep 10, 2001 | 01:45 PM
rioninja's Avatar
Default act 4puck unsprung
does anyone know how much HP the ACT 4 puck clutch can hold if used with a stock pressure plate?
Old Sep 10, 2001 | 02:05 PM
Turbo00's Avatar
New User
Default Re: act 4puck unsprung (RioNinja)
just go with the 6 puck you'll hate the 4 puck it chatters like a mother
Old Sep 10, 2001 | 02:21 PM
rioninja's Avatar
Default Re: act 4puck unsprung (Turbo00)
I dont care about the chatter, just the holding power. I had a 3 puck, and i loved it.
Old Sep 10, 2001 | 02:29 PM
Jared's Avatar
use the 4 puck and an itr pp and you'll love the combination. it's a bit extreme for the street if you use the xtreme pp with the 4 puck, but i used it everyday, just depends on what you're used to.
Old Sep 10, 2001 | 03:01 PM
sgT's Avatar
sgT
Default Re: act 4puck unsprung (Jared)
6 puck will chatter much more than 4 puck.
I use the 4 puck with extreme pp. almost no chatter, but moving around on gravel
can get annoying.
Old Sep 11, 2001 | 10:37 AM
EVOCELICA's Avatar
New User
Default Re: act 4puck unsprung (sgT)
The least amount of surface area that the clutch has with the flywheel and the pressure plate will create more holding power, depending on what the buttons are made of. Usually the one with the least amount will be the most violent, example squeeling, chatter..... I had a 4 puck with copper buttons and it felt like my teeth were gonna fall out of my head when I would engage that bitch. I never once had a clean take off with it while driving on the street. I would never put a solid drive plate 4 button clutch in my daily driver again. With the 6 puck I have now I am able to race at the track with slicks and not have the clutch slip and it is bareable for driving on the streets.
Old Sep 11, 2001 | 11:47 AM
rioninja's Avatar
Default Re: act 4puck unsprung (EVOCELICA)
EVO, which pressure plate were you running with the 4 puck?
Old Sep 11, 2001 | 04:43 PM
EVOCELICA's Avatar
New User
I am using one that my machinest made for me. The company he owns is called RPMservice he makes the big bore throttle bodies for Erick of Erick's Racing Engines in Torrance. The guys name is John Rienhart he doesn't have a webpage but the link is to Erick's he can get you the clutches. www.ericksracing.com
petergriffen
Jun 30, 2006 05:19 AM
NAturalDC2
11
Jul 7, 2005 03:37 PM
B16Hatchcx
Jun 8, 2003 06:59 PM
Pistonhead
Aug 7, 2001 05:37 PM
SwiftTypeR
Jul 5, 2001 04:56 AM
