14.1 & higher compression piston. where can i get them?
Old Nov 12, 2003 | 11:51 PM
YOSOLO CRX's Avatar
Default 14.1 & higher compression piston. where can i get them?
Old Nov 13, 2003 | 01:00 AM
Spartanic's Avatar
Default Re: 14.1 & higher compression piston. where can i get them? (YOSOLO CRX)
JE probably makes them, but why are you running such a high compression? I hope you know that your motor will really need to be fine tuned and strengthened for the kind of compression. Are you building a race car becuase that high of a compression will make your car undrivable on the streets.
Old Nov 13, 2003 | 02:40 AM
kwik93si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YOSOLO CRX &raquo;</TD></TR><TR><TD CLASS="quote">14.1 & higher compression piston. where can i get them?
talk to RS_H22 from IBspec he'll set you up...
Old Nov 13, 2003 | 04:52 AM
1 2 NV's Avatar
IB sells up to 13.9:1 but u can shave the head slightly (which i dont recommend) or u can deck the block for piston to deck clearance which will do the same thing. id ask MAX_CFM (brad) on here first.
Old Nov 13, 2003 | 06:01 AM
631 Teggy's Avatar
Default Re: 14.1 & higher compression piston. where can i get them? (1 2 NV)
14:1 damn thats scary!
Old Nov 13, 2003 | 06:17 AM
b19coupe's Avatar
Tough to get compression up to 14:1 on a stock block. High compression is easier to attain on a sleeved block. The bigger the bore, the higher the compression will be with the same size combustion chamber and piston dome cc's.
Old Nov 13, 2003 | 06:57 AM
YOSOLO CRX's Avatar
im have a 85.5 b18c no piston yet its for mi new setup
i have 13.1 in my motor now runnig 12.3 @108. setup
crower stg3,jg 13.1 comp piston,... haltech E6K ecu
Old Nov 13, 2003 | 09:42 AM
kwik93si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">IB sells up to 13.9:1 but u can shave the head slightly (which i dont recommend) or u can deck the block for piston to deck clearance which will do the same thing. id ask MAX_CFM (brad) on here first.</TD></TR></TABLE>
actually i was talking to IB last week and they said that i could get 15:0:1 90mm pistons for my h22...you've just got to ask for them and they'll get them made.
Old Nov 13, 2003 | 11:30 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YOSOLO CRX &raquo;</TD></TR><TR><TD CLASS="quote">im have a 85.5 b18c no piston yet its for mi new setup
crower stg3,jg 13.1 comp piston,... haltech E6K ecu</TD></TR></TABLE>
IB has "Super Duper" high compression pistons for 85mm and 86mm bores. You might be able to get custom pistons in 85.5mm bore, or you could go 86mm and get the IB "SD's" off the shelf. I think Jeff is out of town, so talk to Rod (IBspechatch).
Old Nov 13, 2003 | 11:47 AM
93ludeSi's Avatar
i know wiseco makes 14's for the h series.
they are ultralight with the short skirts
Old Nov 13, 2003 | 12:27 PM
AllMotorMadness's Avatar
IB Spec Wiseco........sales@importbuilders.com
Old Nov 13, 2003 | 12:39 PM
Rocket's Avatar
Default Re: 14.1 & higher compression piston. where can i get them? (AllMotorMadness)
You want more compression or more power?
Dome shape and ring seal play a big role in power production along with compression.
Old Nov 13, 2003 | 05:14 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: 14.1 & higher compression piston. where can i get them? (Rocket)
Arias' #3330701 yield 14:1 with an LS block & GSR head. They are 85mm however. What set up are you running?
Old Nov 13, 2003 | 08:53 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMadness &raquo;</TD></TR><TR><TD CLASS="quote">
IB Spec Wiseco........sales@importbuilders.com</TD></TR></TABLE>
yrpin5th
51
Dec 29, 2008 05:36 PM
soon2bdropped
Oct 3, 2007 06:28 PM
89a6T
Apr 19, 2006 12:56 PM
1.8T_EG
Jul 6, 2004 08:27 AM
