thougths of skunk2 stg 2 on slightly modded b18c5(searched)
Old Nov 12, 2003 | 10:52 PM
tegedrex's Avatar
Default thougths of skunk2 stg 2 on slightly modded b18c5(searched)
just wanted to get an up to date input on stage 2's with motor that has Hytech header,exhaust, custom b-pipe, j's intake, kenji ecu po6, would like to not have to mess with valve train i.e. replacing springs, and ret.
Old Nov 12, 2003 | 11:17 PM
itr-j's Avatar
Default Re: thougths of skunk2 stg 2 on slightly modded b18c5(searched) (tegedrex)
sounds alright, why not toda or jun package,
the package sounds good u might need some hardcore tuning
Old Nov 13, 2003 | 12:33 AM
NA gs-R 05 C
Guest
Posts: n/a
if you don't want to upgrade your valvetrain, then you shouldnt upgrade your cams to skunk stage 2's, stock valvetrain won't be able to take it. if you don't want to upgrade your valvetrain, maybe you should look into stage 1's.
Old Nov 13, 2003 | 06:07 AM
b19coupe's Avatar
Upgrade the valve train. Running Skunk2 Stage 2's in my stock block ITR, and the motor pulls nicely. If I ever get my SMSP header, it will pull even harder
Old Nov 13, 2003 | 12:13 PM
TyPe_R_GuY's Avatar
Default Re: thougths of skunk2 stg 2 on slightly modded b18c5(searched) (b19coupe)
I am running the Skunk2 Stage 2's (with skunk2 valve springs), JDM ITR header, Injen CAI, Test Pipe, Tanabe Cat Back Ehaust, B&M FPR and Gauge, VAFC, chipped P28, Tuned......and i dynoed at 201.3 whp and 138ft. lbs. of trq. and i have stock compression as well with the stock ITR bottom end
Old Nov 13, 2003 | 12:34 PM
Rob Dizzle's Avatar
Default Re: thougths of skunk2 stg 2 on slightly modded b18c5(searched) (TyPe_R_GuY)
stage 1's are plenty cam for a b18c5
lickety_britches
Jun 4, 2009 01:02 PM
msbhvn_DC2
Mar 8, 2006 08:11 PM
krystianitr
66
Jan 2, 2006 08:08 PM
jdm_loser
Dec 13, 2004 10:18 PM
Shorty C
79
May 12, 2004 04:03 AM
