Iridium vs Nitrous
Old Nov 12, 2003 | 10:36 PM
civicrights's Avatar
Default Iridium vs Nitrous
Does anyone have any experience with running Denso Iridium or any other iridium plugs in a heavy nitrous load. I am concerned that the tip may be too small to disipate the heat. Leading to melting of the plug or even worse detination. There might be other problems that I am over looking. I know that some of the quick class cars are using Iridium plugs but a turbo motor does not have the combustion temperature of a nitrous motor. Any help would be great.
Old Nov 13, 2003 | 12:03 AM
aznxphreak's Avatar
Default Re: Iridium vs Nitrous (civicrights)
Doesn't nitrous fed cars run on a lower temp as opposed to FI cars in that when nitrous disassociates, it's an endothermic reaction, the creating a cooling effect?
Old Nov 14, 2003 | 10:44 PM
Default Re: Iridium vs Nitrous (aznxphreak)
I know what you are thinking and I agree but I was also thinking along the lines of the increased volitilidy of a big nitrous shot and the tip of the plug not being able to reject heat fast enough or absorbing to much heat, leading to detination. I am concerned about the tip of the plug because of the relitively large surface area compared to the amount of material in the tip. This makes it more likely to create detination in much the same way that a rough surface in a combustion chamber leads to detination. This might not be a concern but I would like to hear from some more people that have some experience. Thanks
Old Nov 15, 2003 | 08:14 AM
bump
Old Nov 15, 2003 | 08:22 AM
LudeyKrus's Avatar
Well, when you spray or turbo your motor, you go w/ colder-step spark plugs; these have shorter ground straps that don't absorb much heat, therefore decreasing the chance of detonation.
If the iridium's have a ver small ground strap, then I would not be worried; that's how colder plugs work.
Personally, i would stick to some copper Denso's or NGK's.....what's a big shot to you?
Old Nov 21, 2003 | 10:43 PM
Default Re: Iridium vs Nitrous (LudeyKrus)
I am aware of the colder plug having a shorter ground strap and that helping to avoid detination. I was not thinking of the ground strap but of the electrode of an Idridium plug. Is there a problem with the heat and electrod being so small. Any info from people that have experience with this situation.
Old Nov 30, 2003 | 09:31 AM
GS-Rcivic's Avatar
all i know is i melted an iridium plug on 75 shot. My car was not tuned and it was detonating like a motha thats why my head gasket is blown right now
Old Nov 30, 2003 | 12:59 PM
RyanEJ8's Avatar
NGK BKR7E gapped at .030 is what you want.
Old Nov 30, 2003 | 01:28 PM
Kendall's Avatar
I never had a problem running Denso Iridium's with a 75 shot. In fact the engine was notably more responsive to driver input running the Iridium's vs Bosch Platinum's that were in the vehicle before.
Old Dec 1, 2003 | 08:31 AM
RyanEJ8's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">I never had a problem running Denso Iridium's with a 75 shot. In fact the engine was notably more responsive to driver input running the Iridium's vs Bosch Platinum's that were in the vehicle before.</TD></TR></TABLE>
Running platinum plugs with nitrous was a BIG mistake.
K20ISR
Mar 30, 2009 07:27 AM
Slic00Si
May 16, 2004 09:24 PM
nos3tc
Jan 17, 2004 07:49 AM
