LS/VTEC car wont start unless i step on gas bad idle sometimes even dies
Old Nov 12, 2003 | 09:38 PM
mts.'s Avatar
Default LS/VTEC car wont start unless i step on gas bad idle sometimes even dies
as topic says i also did search tried most of them anyone else have this problem. it also feels like high and low high and low untill i give unough gas about 3 4k it evens out. hELPPP!!!!
Old Nov 12, 2003 | 11:39 PM
mts.'s Avatar
almost feels like something is clogged
bump
Old Nov 13, 2003 | 06:16 AM
ultimatehonda's Avatar
Default Re: LS/VTEC car wont start unless i step on gas bad idle sometimes even dies (mts.)
Sounds like ur idle control valve isnt functioning. May want to look at that.
Old Nov 13, 2003 | 12:07 PM
mts.'s Avatar
thanks ultimate honda. the funny thing is the car was fine til i took the head off. all i did was sent it to the machine shop, they honed and ported, and put on some new vale stem seals, i put a new gasket, copper spray, a new coolant sensor and thats it. how did the iacv go bad, it was fine 3 days ago. anyone help? ima check out the iacv any how.
Old Nov 13, 2003 | 02:31 PM
turbohondask's Avatar
Default Re: (mts.)
vaccum leak, what throttle body are you using?
Old Nov 13, 2003 | 02:58 PM
poison's Avatar
Do a compression check. Sounds like you might have a vacuum leak as well...
Any CEL's?
Old Nov 13, 2003 | 07:51 PM
mts.'s Avatar
cant do a compression check til monday, im using gsr throttle body and gsr manifold. my brother adjusted the throttle cable so it doesnt die when its started. i pulled out the iacv and checked it out it was clean i also switched with my homies gsr and it still bogs. iacv it is not, if i can get a fuel filter for cheap ima change that out any how. hopefully i can get one for 8 bucks. i also checked the vacuum lines nothing looks like its off and cant really hear anything leak the instructor gave up on it too he said it maybe vacuum leak but then we couldnt find it. he said he does like hybrids(haterrrr). any how, i might have to chek the vacuum's again in a bit.
oh yea and the car doesnt bog as much in startup anymore until it warms up it starts going up and down really bad.
Old Nov 13, 2003 | 07:53 PM
mts.'s Avatar
could it be that something is clogged? maybe fuel injectors???
Old Nov 13, 2003 | 08:42 PM
dohcnotec's Avatar
Default Re: (mts.)
Switch your TPS and Map sensor plugs.
Old Nov 13, 2003 | 10:28 PM
blwnb16a's Avatar
Default Re: (dohcnotec)
check your timing
Old Nov 13, 2003 | 10:38 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
I had the same problem switched the plugs at the map and tps and everything was fine
Old Nov 13, 2003 | 11:00 PM
mts.'s Avatar
timing is fine did it twice ill try switching tps and map sensor plugs
Old Nov 13, 2003 | 11:23 PM
mts.'s Avatar
just switched plugs wont be able to tell til tomorroow exhaust is too loud anyone wanna trade??? in socal???
any how, i gotta question for those who know, what does switching tps and map sensors do? i know the volts are different one is .2??? and the other is .4??
Old Nov 14, 2003 | 12:55 AM
dohcnotec's Avatar
Default Re: (mts.)
The ecu collects information from each sensor independently and uses it to calculate timing & fuel. If you have the wire(s) switched, the ecu is getting incorrect info, resulting in a horrible running car. Also, the Map & TPS are the 2 most important sensors you have (next to crank/tdc) so if these signals are messed up, you will know.
Old Nov 14, 2003 | 03:30 AM
KOME's Avatar
New User
Sounds like the same problem I'm having with my car. Here's the thread:
https://honda-tech.com/zerothread?id=655873
mts, can you confirm if this is the same issue? I can't seem to find WHAT the problem is...
Old Nov 14, 2003 | 09:37 AM
mts.'s Avatar
thanks kome yea its same problems too i had to adjust my throttle cable just to get it to start up but it still bogs
Old Nov 14, 2003 | 09:44 AM
mts.'s Avatar
ok well started up car just now and still bogs seems almost like worse than usual but its cold and i changed the plugs back so
tps switch to map sensor check
looked at iacv check
vacuum leaks check
new plugs check
spark plug wires check
Old Nov 14, 2003 | 10:47 AM
o1.bizzy.1o's Avatar
mts got banned **** FALCON GSR and **** djaira
they couldnt hang lol they took my sig offensive fuckit. ..
"your all a bunch of ******' ********.......u know why??? cause u dont have the guts to be what u wanna be!!! u need people like me!!! u need people like me so u can point ur ******' fingers, and say thats the bad guy!!!"- tony montana
Old Nov 14, 2003 | 11:33 AM
gaydm.accord's Avatar
bump it up
Old Nov 14, 2003 | 01:59 PM
gunslinger's Avatar
Default Re: (gaydm.accord)
I had a b16 crx stolen and I am glad he got banned if that is what he does or used to do . Once a theif always a theif!!! I dont like helping thiefs. I hope his car NEVER gets Fixed!!!
Old Nov 14, 2003 | 02:04 PM
gunslinger its people like you that make theives exist, who knows i hope mts does decide to turn into a thief again and maybe steal your car, hes a close friend of mine i see why he put it on his sig because people on h-t are so uptight that way. and you guys that get butt hurt need to stop crying material things are replaceable think about the **** that matters instead of your **** that got stolen what he did was in the past he learned from it and once a thief always a thief huh? i bet you've stolen something before and 9out of 10 people have stolen in their whole life just a fact i like to throw in there
Old Nov 14, 2003 | 06:37 PM
gunslinger's Avatar
Default Re: (o1.bizzy.1o)
Somebody ban this guy
Old Nov 14, 2003 | 06:42 PM
gunslinger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o1.bizzy.1o &raquo;</TD></TR><TR><TD CLASS="quote">gunslinger its people like you that make theives exist, who knows i hope mts does decide to turn into a thief again and maybe steal your car, hes a close friend of mine i see why he put it on his sig because people on h-t are so uptight that way. and you guys that get butt hurt need to stop crying material things are replaceable think about the **** that matters instead of your **** that got stolen what he did was in the past he learned from it and once a thief always a thief huh? i bet you've stolen something before and 9out of 10 people have stolen in their whole life just a fact i like to throw in there</TD></TR></TABLE>
It is the same dude!!!!
Old Nov 14, 2003 | 06:48 PM
gunslinger's Avatar
Default Re: (gunslinger)
I have gotten over my car being stolen . But Im not going to be taken so easily next time. That is why I bought a new security system. It travels at over 1100ft per second and you cannot out run it so bring it on "you must not want to live". My stuff may be material stuff but it does matter to me when it is stolen. You are not replaceable but I bet when your gone knowone will even miss you.
Old Nov 14, 2003 | 08:06 PM
mntuner2's Avatar
Blah loser
