BRAKE question mushy brakes
Old Nov 12, 2003 | 09:04 PM
Tony R's Avatar
Default BRAKE question mushy brakes
Brake question to stop my car I have to put the brake pedal to the metal and its real mushy and I can't register my car in maryland unless I PASS the inspection. And the dude that did the inspection said I have to replace my whole master cylinder in order to correct this problem to pass the inspection. I'm a rookie and really don't want to play with my brakes well not yet anyway . So any idea what could the problem be or a solution that does not involve replacing my master cylinder it would really take away from my rotor and brake pad upgarde budget.
Old Nov 13, 2003 | 12:57 AM
King_j's Avatar
Default Re: BRAKE question mushy brakes (spd4tegy)
check the fluid level in the master cylinder. you could have a leak somewhere.
Old Nov 13, 2003 | 02:23 AM
HiRevn's Avatar
Default Re: BRAKE question mushy brakes (King_j)
You could try bleeding the brakes and make sure there's no air in the lines. A mushy pedal usually is a sign of a master cylinder going bad. Doesn't mean it is though.
Old Nov 13, 2003 | 06:27 AM
andrew dc's Avatar
Default Re: BRAKE question mushy brakes (HiRevn)
bleed the lines, check the pad thickness... then go for the mc or maybe booster failure.
Old Nov 13, 2003 | 10:16 AM
BrownGSR's Avatar
this happened to me, got a type r mc and brake booster, but beware the fitting going into the master cylinder is different than my stock on so i also had to replace this. By the way i LOVE the feel of the type r master cylinder, much better pedal control
Old Nov 13, 2003 | 02:51 PM
Tony R's Avatar
Default Re: BRAKE question mushy brakes (BrownGSR)
SO where is a good place to get a type r mc from I'm have bad luck looking for one
ribal_gh
11
Apr 30, 2013 04:24 AM
Markb16a
13
Apr 13, 2010 11:25 AM
pedroa06
Sep 3, 2009 06:23 PM
bb4socal
Sep 4, 2006 09:51 PM
MrEg
Sep 22, 2003 04:49 PM
