LS/VTEC Compression Question
Old Nov 12, 2003 | 08:33 PM
MugenB16A2's Avatar
Default LS/VTEC Compression Question
OK, here's my deal:
95 LS block, LS Crank, LS Rods, ARP Rod Bolts, etc.
CTR PISTONS STD BORE
Am I going to have any problems running this with a '99 B16A2 head??? as far as the Piston smaking the Valves because CTR Pistons have HUGE Domes???
What about pump gas, Here in FL we have 93 Octane will I be OK???
Please let me know if any of you have these pistons in you LS/VTECs and let me know what you think the Compression Ratio will be.
Thanks.
Old Nov 12, 2003 | 09:10 PM
gsrvx's Avatar
New User
Default Re: LS/VTEC Compression Question (MugenB16A2)
12.2:1
Clearance should be fine.
Old Nov 12, 2003 | 09:51 PM
MugenB16A2's Avatar
Default Re: LS/VTEC Compression Question (ibspecHATCH)
SHOULD be fine???
This isn't checkers we're playing here. I need concrete YES/NO answers, this is alot of money I'm dealing with.
Someone must be using CTR STD Bore pistons in their LS/VTEC with a B16A2 head.
Old Nov 12, 2003 | 10:40 PM
omega11855's Avatar
why dont you clearence yourself and tell us what size headgasket you had to use for proper clearence?
Old Nov 12, 2003 | 11:00 PM
gsrvx's Avatar
New User
HAHA.
OK...how about YES. Does that make u feel better? I'm sorry my wording presented doubt.
YES YOU WILL BE FINE...even with your stock high lift b16a2 cams
I know someone who used to have an lsvtec, gsr head, milled .030'', jun3s, ctr pistons....clearance was fine.
Old Nov 13, 2003 | 07:30 AM
MugenB16A2's Avatar
Would TODA SPEC A or B cams give me any problems as far as having a High lift and longer duration of lobes???
Old Nov 13, 2003 | 08:37 AM
gsrvx's Avatar
New User
I've seen setups where the clearance was OK...but in all honestly...I would clay the motor to be 100% sure.
Rod
Old Nov 13, 2003 | 11:48 AM
MugenB16A2's Avatar
Clay??? Can I get some detailed onfo on this Claying process? Or possibly a link???
Old Nov 13, 2003 | 01:01 PM
gsrvx's Avatar
New User
No problem....here ya go:
http://www.c-speedracing.com/h...y.php
Rod
Old Nov 13, 2003 | 02:21 PM
MugenB16A2's Avatar
What is sufficient Piston-Valve clearance???? As far as Numbers, not explaining the meaning.
Old Nov 13, 2003 | 03:04 PM
MugenB16A2's Avatar
Btw Rod, I went to C-Speed Racings CR calculator and it came out to be 12.3:1, NOW will that be safe for 93 Octane???
Old Nov 13, 2003 | 06:36 PM
gsrvx's Avatar
New User
0.035''
I've always heard that c-speeds comp calculator is a bit off. Most people say that Bojangs calculator is most accurate. http://www.bojangs.com/calculator/
I think that is fine on 93 octane. Tune it. Very important.
Old Nov 13, 2003 | 07:25 PM
MugenB16A2's Avatar
thanx,
btw, Rod, please give me your thoughts on which Valvetrain to buy on my other poll:
https://honda-tech.com/zerothread?id=677276
Old Nov 14, 2003 | 06:09 AM
jdmcx's Avatar
you should be fine i am running a b18a block with ctr's against a gsr head with a 2 layer gasket and it is fine i also run pump (93 octane) with only a regulator and 255 pump
Old Nov 14, 2003 | 09:13 AM
MugenB16A2's Avatar
Default Re: LS/VTEC Compression Question (jdmcx)
Thanx JDMCX
iseecivic
Feb 12, 2006 08:00 AM
unix4linux
17
Nov 16, 2005 10:33 AM
ID_ten_T
Jun 15, 2003 04:14 PM
arw321
May 9, 2003 03:12 AM
spookhatch24
Jan 2, 2003 12:18 PM
