98 gsr dash swap into an EG6??
Old Sep 10, 2001 | 12:52 PM
civichb's Avatar
New User
Default 98 gsr dash swap into an EG6??
i have seen people done it on net. I am actually curious if this is a hard job to do. I am buying the dash from a junk yard for cheap. can someone give me some opinions on this ? Thanks alot!
Old Sep 10, 2001 | 03:40 PM
Bumnah's Avatar
Default Re: 98 gsr dash swap into an EG6?? (civichb)
i've seen the dash in an eg. it looks freakin' beautiful.
i think you need the heater core, and a lot of the wiring that goes under the dash.
i also belive there is a piece of metal by where the cluster would go, and it's also near the steering colum. you need to cut that metal piece off, and i think the dash pretty much just goes right on.
honda dashes are actually one of the easier dash to take out of the car.
only about 6-10 bolts holding the dash on rest of it is clipped on i believe.
either way just a long time to do the swap, but should go in easy. set aside a whole weekend for the swap.
l8r duuuuuuuuude
evsproject94
Apr 2, 2004 07:11 AM
B18Cej1
Feb 11, 2004 03:31 PM
Grip
11
Feb 9, 2004 03:26 PM
N~FaMouSKhMerBoi
Oct 10, 2002 08:21 AM
