ef1 m24 cams?
Old Nov 12, 2003 | 07:44 PM
lke2drvgsr's Avatar
Default ef1 m24 cams?
i have a gsr block (balanced and blueprinted, cyl walls honed) .25mm overbored jdm itr pistons, shotpeened rods, skunk2 stage2 cams/retainers/valves/springs, skunk2 IM, b16 p&p head... could the ef1 cams give me good gains over the skunk2 stage 2's that i have now? and does anyone have dyno charts? i really want info on these as i need more power, like we all do!!
Old Nov 12, 2003 | 08:01 PM
99skunkedSi's Avatar
Default Re: ef1 m24 cams? (lke2drvgsr)
I dont know a lot about those cams, but im curious on what kind of power your making with your current set up? I have a similar set up but in a b16a2
Old Nov 12, 2003 | 08:09 PM
eddiecut's Avatar
Default Re: ef1 m24 cams? (99skunkedSi)
i think those will be a little to big of a cam for your set up, m24s are some nasty cams, you might wanna look at the 23s or 22s, i have heard they make some good power all around
Old Nov 12, 2003 | 08:17 PM
lke2drvgsr's Avatar
Default Re: ef1 m24 cams? (eddiecut GanGsTa)
im waiting to get it dyno'ed with my hondata s200 so im not sure on the numbers.. i also have a jdm itr tranny w/lsd/4.785fd, and act clutch/lightened flywheel + i/h/e, but im not sure on my numbers... i'll look into the 23's, but id like to see some dyno's and more info on these thanks for the replies
Old Nov 13, 2003 | 03:57 AM
GOLDBERG's Avatar
i'll have a dyno of these in a few weeks..as long as IB can provide me with the pistons i want.. 12.1cr 84mm gsr, jg pnp head, an-r header, victor x manifold, 68mm tb, chipped ecu , 370cc injectors and a vafc
Old Nov 13, 2003 | 05:34 AM
KoRE's Avatar
Default Re: ef1 m24 cams? (GOLDBERG)
i should have a dyno of them real soon, i'm dropping my motor in next week then getting it tuned.
Old Nov 13, 2003 | 07:12 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">i'll have a dyno of these in a few weeks..as long as IB can provide me with the pistons i want.. 12.1cr 84mm gsr, jg pnp head, an-r header, victor x manifold, 68mm tb, chipped ecu , 370cc injectors and a vafc</TD></TR></TABLE>
victor x manifold?? that thing won't let you see power gain till like past 7k..everywhere below that is usually a loss unless you're FI
Old Nov 13, 2003 | 08:03 AM
Rob Dizzle's Avatar
m24 is way too big for your setup
you need to have 2.0L+ and 12:+ cr
your stage 2's are even bigger than you need prolly. you maybe gained 1-3.5 whp up top compared to stage 1's
spend your money else where
what header do you have?
unless you have a good header (not jdm 4-1) then you can easily make more power elsewhere
Rob Dizzle's Avatar
Default Re: ef1 m24 cams? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
victor x manifold?? that thing won't let you see power gain till like past 7k..everywhere below that is usually a loss unless you're FI</TD></TR></TABLE>
he knows, he got it with his swap that he bought. he gona prolly get anohter one soon when more gsr IM's come out
Old Nov 13, 2003 | 08:14 AM
AllMoToRB18c's Avatar
Default Re: ef1 m24 cams? (Bob-DC2)
i think u need a lot higher compression then what u got to run that m24's
Old Nov 13, 2003 | 09:06 AM
lke2drvgsr's Avatar
i can't wait to see all these dynos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">m24 is way too big for your setup
unless you have a good header (not jdm 4-1) then you can easily make more power elsewhere</TD></TR></TABLE>
so then what kinds of gains would i see over my stage 2's? and would i see good gains from the 23's?
thats one hell of a setup dude.. nice i have shitty dc 4-2-1 headers which do jack ****, and i was looking into headertech and a high flow cat (ive got stock cat)... but thats 700+ bucks... yes the ef1 cams are 750 bucks, but i could sell my stage 2's for around 600 or so.. i couldnt sell my dc for 600 lol
Old Nov 13, 2003 | 09:30 AM
Unsung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">i have shitty dc 4-2-1 headers which do jack ****, and i was looking into headertech and a high flow cat (ive got stock cat)...</TD></TR></TABLE>
The header will do a lot more for you than EF-1 cams since you already have a good cam setup. I would go with the header-tech or DTR header, I guarantee you won't be sorry.
Old Nov 13, 2003 | 09:45 AM
Rob Dizzle's Avatar
you are wasting your time and money in getting cam shafts that wont do much of a difference
get a better header, with a true 2.5 exhaust then get it tuned. and call it a day
going with a bigger chamshaft will prolly just shift your power band up
Old Nov 13, 2003 | 10:35 AM
lke2drvgsr's Avatar
are you sure i wouldnt be seeing much gains with m23 cams?
Old Nov 13, 2003 | 10:39 AM
Rob Dizzle's Avatar
maybe 2-4 peak hp. not much every where else
you need high compression or a bigger displacement
you are only 11.0 cr: ? or around there?
Old Nov 13, 2003 | 10:43 AM
lke2drvgsr's Avatar
actually im not quite sure what compression im running right now, im waiting to get it tuned (ive been waiting for 3 months.. ) i should be around mid 11's though, shouldnt i?
Old Nov 13, 2003 | 10:59 AM
Rob Dizzle's Avatar
with a b16 head you should be at 11.0 assumming you are running a stock headgasket and your head isnt milled
i know someoen that has ajdm itr swap with a built head.
he had stage 2s with smsp header and tuned with hondata
he lost about 1-3whp from 7k to 8.5k going with stage 1's
the power is in having everything good on your setup.
just like on rocket sig. you need to have all the igredients to have a fast motor. not just big cams with mild compression and bad flowing intake and exhaust parts
if you want big power, go with a smsp, hytech, or another custom big tube header.
dont cry about the price, cause if you want to play with the big doggs and be fast, you need to pay to get there. speed costs money
edit: just from switching to a AEBS im that is mildly port and polished, or to a rlz intake manifold with a properly sized t-body. you will gain more than going with whatever brand cams, toda b's; jun 3's;
you might make more power way up top with bigger cams, but you want the biggest area under the curve. not just have a big peaky curve where your tq curve isnt flat
Old Nov 13, 2003 | 11:21 AM
JDM2ndGen's Avatar
im thinking about runnning the m24's in mt setup 2.0 ls/vtec ...does anyone know what compression they work best with ...i was thinkin about 12.5. ...and as for a header i was thinking about goin with DTR or SMSP...
Old Nov 13, 2003 | 11:47 AM
lke2drvgsr's Avatar
Default Re: ef1 m24 cams? (JDM2ndGen)
thanks for the info bob, nothin ever comes simple, does it? lol when i get a job, i'll look into headertech, but smsp is just wayyyy too costly
Old Nov 13, 2003 | 12:21 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">im thinking about runnning the m24's in mt setup 2.0 ls/vtec ...does anyone know what compression they work best with ...i was thinkin about 12.5. ...and as for a header i was thinking about goin with DTR or SMSP...</TD></TR></TABLE>
at least 13.0 if i were going to do it.
if you are gona have a daily driver on pump gas then you can only prolly get away with sub 13 with 94 octane
otherwise m23 or m22 is plenty cam for a daily driven car
if you can afford the smsp header, go with that one.
Old Nov 13, 2003 | 12:36 PM
Rocket's Avatar
A better IM may be beneficial. There are alot of gains to be made with a good IM.
Same goes for headers.
Old Nov 13, 2003 | 01:02 PM
JDM2ndGen's Avatar
</TD></TR></TABLE>that for the info ...if i do go for the m24's ill go for around 13.0 ..but if i go for the m23's ill prob have the compression around 12.5 ...and right now im decideing between the DTR header and the SMSP ...i think im goin to go with the SMSP ...is there a site where i can look more into the SMSP header ?
Old Nov 13, 2003 | 03:43 PM
GOLDBERG's Avatar
hmm so what cr is the m24's gfood for??rocket told me i;d be fine in the 11's but i was set on 12.1
Old Nov 13, 2003 | 03:44 PM
GOLDBERG's Avatar
oh well it was free what can i complain and i dont plan on making peak power below 7k so...
Old Nov 13, 2003 | 05:35 PM
MikeySpec's Avatar
has anyone posted any real world dyno's of these cams yet?Im intrested in them....but i guess no one has come through on any numbers yet?
