quick jdm itr shift knob question
really really quick question but....
guys with jdm itr shift **** do you guys use that little bolt that comes with the shift ****?
looking at some pics when i searched, doesn't seem like there using the bolt?
have you put it on the shifter yet? because, you need the bolt to act as kind of a spacer. It helps you to line up the shift **** so that the numbers are not sideways
Hope that makes sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone »</TD></TR><TR><TD CLASS="quote">have you put it on the shifter yet? because, you need the bolt to act as kind of a spacer. It helps you to line up the shift **** so that the numbers are not sideways
Hope that makes sense</TD></TR></TABLE>
Ditto , IMO the it looks better with the bolt
that nut is called a reverse thread nut, and yes like everyone says, its to keep your **** aligned... it's also good to have, if you power shift like i (and others) do. it keeps your **** from swivelling around...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t »</TD></TR><TR><TD CLASS="quote">Its a nut
,not a bolt.</TD></TR></TABLE>
Touche!
,not a bolt.</TD></TR></TABLE>Touche!
done
Oct 10, 2002 06:24 AM
is for
