Is this true...DX and SI have the same automatic trannies?
Old Nov 12, 2003 | 06:04 PM
EL-Driver's Avatar
Default Is this true...DX and SI have the same automatic trannies?
Are they the same yes or no?
Cause my auto tranny on my Civic SI just went kaboom!!!!!!!!!
and well too my luck, someone is sellin me a auto tranny from a dx and he said to me the auto tranny is the same as the SI...
Old Nov 12, 2003 | 06:21 PM
rasta420's Avatar
Default Re: Is this true...DX and SI have the same automatic trannies? (EL-Driver)
i didnt know that they made Si's with auto transmissions...
Old Nov 12, 2003 | 06:22 PM
aces1980's Avatar
i don't think they did either
Old Nov 12, 2003 | 06:45 PM
redcivic90's Avatar
Default Re: (aces1980)
In igloo country (Canada) Si's had optional auto transmissions. I believe they are the same as CX/DX ones if they are from a HB. Sedan ATs have a different 4th and final gear ratio. Anyways, either should bolt up and work since both are D series engines.
The service manual lists different specs for HB MTs for 1.5L and 1.6L models... but only one set of specs for HB ATs.
Old Nov 12, 2003 | 09:42 PM
Vinceg99's Avatar
Default Re: (redcivic90)
Hmm? I also have a DX tranny for sale. I didnt know it was the same as the Canadian Si though? But then again nobody has ever asked me so why would I have had to know? But anyway if you need one I got one!
Old Nov 13, 2003 | 05:01 AM
ImportsCRX's Avatar
Default Re: (Vinceg99)
Auto being optional in an Si? Yuck
Old Nov 13, 2003 | 05:52 AM
Limited S.L.I.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt know that they made Si's with auto transmissions...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivic90 &raquo;</TD></TR><TR><TD CLASS="quote">In igloo country (Canada) Si's had optional auto transmissions. </TD></TR></TABLE> interesting, a kid I met from The virgin Islands showed me pics of his RHD B16 SIR.. it was also automatic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivic90 &raquo;</TD></TR><TR><TD CLASS="quote">I believe they are the same as CX/DX ones if they are from a HB. Sedan ATs have a different 4th and final gear ratio. </TD></TR></TABLE> I don't have one, but just curious the diff between the fourth and final gear ratios of the sedan and hatch? Anyone know which would be preferred should you need an auto?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivic90 &raquo;</TD></TR><TR><TD CLASS="quote">Anyways, either should bolt up and work since both are D series engines.The service manual lists different specs for HB MTs for 1.5L and 1.6L models... but only one set of specs for HB ATs.</TD></TR></TABLE>good to know.
gameeffect
19
Nov 2, 2004 10:11 PM
EL-Driver
Nov 26, 2003 09:36 PM
Jay J
33
Jul 3, 2003 03:58 PM
aonick
Apr 24, 2002 07:58 AM
