Anyone know what this is???...hooks up to Throttle Position Sensor
Old Nov 12, 2003 | 05:42 PM
GSR-T-'s Avatar
Default Anyone know what this is???...hooks up to Throttle Position Sensor
Old Nov 12, 2003 | 05:49 PM
GSR-T-'s Avatar
those three wires hook up to a sensor(im pretty sure its the Throttle Position Sensor) and the other is a vacum line to the intake manifold
Old Nov 12, 2003 | 06:05 PM
Daemione's Avatar
Default Re: (GSR-T-)
All I can think of is a gear kickdown switch for an automatic tranny.
Where'd it come from?
Old Nov 12, 2003 | 06:34 PM
BluLude's Avatar
Default Re: (Daemione)
i think its a MAP sensor, what kinda car is it for a chevy?
Old Nov 12, 2003 | 06:44 PM
GSR-T-'s Avatar
its off a type R turbo motor that I just bought
Old Nov 12, 2003 | 06:45 PM
GSR-T-'s Avatar
could it have anything to do with the hondata?
Old Nov 12, 2003 | 06:50 PM
BluLude's Avatar
Yea its i believe a 3bar gm map sensor
Old Nov 12, 2003 | 06:51 PM
rathead's Avatar
its a 3bar gm map sensor.
Old Nov 12, 2003 | 07:06 PM
GSR-T-'s Avatar
i thought the map sensor was something else....I disconnected this piece from wires spliced off the Throttle Position Plug
Old Nov 12, 2003 | 07:12 PM
Adam F's Avatar
Default Re: (rathead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead &raquo;</TD></TR><TR><TD CLASS="quote">its a 3bar gm map sensor.</TD></TR></TABLE>
That would be my guess
Old Nov 12, 2003 | 07:20 PM
GSR-T-'s Avatar
does anyone know how to hook up these three wires (A B C)
Old Nov 12, 2003 | 08:47 PM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">i thought the map sensor was something else....I disconnected this piece from wires spliced off the Throttle Position Plug</TD></TR></TABLE>
its a gm map sensor and u prolly disconnected it from the stock map sensor wires unless the person who originally wired it up was an idiot and wired it into the tps
Old Nov 12, 2003 | 09:01 PM
GSR-T-'s Avatar
ok I figured it out thanks guys now I have it hooked back up right
joe
Old Nov 12, 2003 | 09:13 PM
Ryan C's Avatar
3 mbar map...must be runnin 12+ psi
Old Nov 13, 2003 | 12:03 AM
HYBRID_H@TCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to hook up these three wires (A B C)</TD></TR></TABLE>
Splice the three wires into the existing wiring loom so that you can swap between the MAP sensors if necessary, or revert back to the stock MAP sensor. Make sure that only one MAP sensor is connector at a time. These colours are for early model Hondas
Wire Sensor Code Wire Color
GND A Green/White
MAP signal B White
5V C Yellow/Red
Old Nov 13, 2003 | 07:54 AM
Rtype16's Avatar
Default Re: (99Hybrid_Hatch)
Do you have a computer on your vehicle? If you do you may have to re-scale it for this sensor. Also you should really find out by part number if it is a 3 bar, 2 bar or 1 bar map sensor.
T9U4ReBgO
Feb 20, 2008 05:55 PM
allnaturalb16
Oct 19, 2007 10:14 PM
GhostInTheShell
Mar 19, 2007 05:25 PM
'90crxSI
May 23, 2006 06:53 AM
comptechgsr2000
May 8, 2002 03:53 PM
