going to buy sparco sprints....
Old Nov 12, 2003 | 05:04 PM
Your Epitaph.'s Avatar
///M Power
Default going to buy sparco sprints....
im going to buy two sparco sprints as well as two of sparco's four point driver harnesses. my question is what all do i need to buy (aside from the seats and harnesses) to make this setup work (brackets, sliders etc.) i need to know everything i need to buy so i can calculate how much this is all going to cost...i already removed my back seats to be able to bolt the harnesses into...but can somebody show me a pic or diagram as to where they bolt onto? thanks.
Old Nov 12, 2003 | 05:13 PM
BolivianDc2's Avatar
Default Re: going to buy sparco sprints.... (J_D_M_9_4)
I think you might want to consider Sparco Speeds if this is a daily driver, they feel better than Sprints supposedly and have protection against wear.
The way to mount your harness is to all the stock seatbelt locations. The only place you might have a problem is the right side of the lap belt, where you might have to drill a hole through the car to get it to mount properly (or just run it to the right rear lower bolt that holds the slider, but its unsafe)
Old Nov 12, 2003 | 05:14 PM
Default Re: going to buy sparco sprints.... (Bolivianstrtwpn)
you also need seat brackets, yes
zerovandez
Mar 31, 2011 02:06 PM
Type Ek
12
Feb 27, 2007 01:29 PM
QTKEG6
Sep 27, 2002 08:51 PM
underrated99si
May 20, 2002 07:29 PM
