OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!!
Old Nov 12, 2003 | 03:30 PM
Drum_Guru's Avatar
Default OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!!
Wow... im not sure what to think... OK... My engine is 78000 miles old... I just noticed that btw 1k and 2k rpms my car makes funny rattling noises... someone tell me if this is common or what... is this somethin easy to fix... im almost excited bcz this would give me a reason to build my engine!!!! Im also pissed bcz its a damn Honda... its supposed to go 4eva...??? HLEP PLZ!!!! Thanks.
Old Nov 12, 2003 | 03:32 PM
naujcdl's Avatar
Default Re: OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!! (Drum_Guru)
what do you have done to your engine, mod wise, cat-back, headers, intake???
that would give us a better idea of what you are having problems with...
Old Nov 12, 2003 | 03:36 PM
del_parker's Avatar
you have too many angry hampsters in there, need to remove a few of them.
can you be a little more descriptive of the noise and where it's coming from?
Old Nov 12, 2003 | 03:43 PM
Drum_Guru's Avatar
Default Re: OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!! (del_parker)
ok... the only mods are intake (3in. generic), cat-back exhaust (2 1/4in. apexi Dunk)... ok the noise sounds like its from the engine... it is like a whirring click... i dunno it almost sounds like a bad piston maybee.... i dunno... BLAAHHHHHH!!!!!! anyways... what do yall think...
Old Nov 12, 2003 | 03:46 PM
del_parker's Avatar
is the noise coming from the head or the block?
Old Nov 12, 2003 | 03:53 PM
Drum_Guru's Avatar
i dont know... it might not even be the engine, but it only happens btw 1k and 2k rpms... so im guessin its like the crank/rods or something...
Old Nov 12, 2003 | 04:55 PM
BolivianFuego's Avatar
Might be a heatshield rattling. Check that out first.
Old Nov 12, 2003 | 05:03 PM
DisturbingFactor's Avatar
Default Re: OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!! (BolivianFuego)
5speed or Auto? The Auto transmission in Prelude is shot and when i start the car it makes a semi loud rattling noise but it's something in my transmission....Damn Autos.
Old Nov 12, 2003 | 06:13 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Might be a heatshield rattling. Check that out first. </TD></TR></TABLE>
does the ratteling get faster as the rpm's increase?
Old Nov 12, 2003 | 06:22 PM
naujcdl's Avatar
Default Re: OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!! (SKDRCR)
i think he has the same problem as i do, current setup on signature, and it happens only when i am in the 1.5 - 2.5 k rpm range, it is a rattling coming from the union of the header to the cat or somewhere around there, but then again, i have to double check my bolts and see what is wrong.
Old Nov 12, 2003 | 06:26 PM
SKDRCR's Avatar
Default Re: OMG WHAT IS IT???? my engine just started making a rattling noise!!!!!! (naujcdl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naujcdl &raquo;</TD></TR><TR><TD CLASS="quote">i think he has the same problem as i do, current setup on signature, and it happens only when i am in the 1.5 - 2.5 k rpm range, it is a rattling coming from the union of the header to the cat or somewhere around there, but then again, i have to double check my bolts and see what is wrong.
mine did the same thing at low rpm's you
could feel the vibration, turned out to be the heatshield,
nothing a little screwdriver couldn't take care of
Old Nov 12, 2003 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
nothing a little screwdriver couldn't take care of </TD></TR></TABLE>
Yep prolly heat shield as i stated before. Now go drink More
Old Nov 12, 2003 | 06:50 PM
Drum_Guru's Avatar
yeah ill check the heatshield... its def. a 5-spd though... y would you get an automatic "sporty car"...
Old Nov 12, 2003 | 07:21 PM
na foo its john's Avatar
i have an automatic sports car
Old Nov 12, 2003 | 07:29 PM
naujcdl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">y would you get an automatic "sporty car"...</TD></TR></TABLE>
cuz, i wanted it and i am in chicago, lots of traffic and snow, snow...i love my car it is fast when i want it too and i don't need more.
Old Nov 12, 2003 | 07:33 PM
Drum_Guru's Avatar
...that works... personal prefrence i guess... cool... i got my info... this can die
Old Nov 12, 2003 | 07:42 PM
Jeff33S's Avatar
If none of the above clears it up has the timing belt been changed?
-Jeff-
Danjal
Nov 27, 2008 11:51 AM
FGalaxyR18
Honda Civic (2006 - 2015)
Feb 1, 2007 07:14 AM
redliner8000
Feb 19, 2004 08:49 PM
obsidianG35
Sep 4, 2003 08:55 AM
