skunk2 stage 2 rebuild in 99 si
Old Nov 12, 2003 | 02:14 PM
HatchBox's Avatar
Skoobie no more...
Default skunk2 stage 2 rebuild in 99 si
my friend just had his head all rebuilt, he put in
skunk 2 stage 2
cams
cam gears
valves
retainers
intake manifold
he also added a aem fuel rail and regulater
he is currently running on the VAFC II
*problem*
he got the car back all rebuilt last night (11/11) the shop he had do it let the car run for aprox 30 min. then he drove it home about 50 miles or so, now he didnt really go hard on it untill he got it almost home, then he let it go past vtec, but he said that it doesnt seem to engage, the VAFC says its kickin on but it doenst pull or sound like its getting vtec.
*cliffnotes if u were to lazy to read
friend got skunk 2 stage 2 head rebuild...now it seems to not hit vtec.
Old Nov 12, 2003 | 02:45 PM
slowazzhatch's Avatar
Default Re: skunk2 stage 2 rebuild in 99 si (ind3ciso)
check your oil level, your vtec pressure switch, everything, start with small stuff, is the shop a known shop? - do you trust their work? it all else fail pull the valve cover off and inspect
Old Nov 12, 2003 | 06:08 PM
michael O's Avatar
I dunno if this is the problem but skunk2 stage 2's require high than stock compression to make real power. He should also probably dyno tune it.
Old Nov 12, 2003 | 08:23 PM
mel_2kgsr's Avatar
i think there are too many variables....take it back and have the shop look at it since it'll be free anyways...
Old Nov 12, 2003 | 08:42 PM
CleenSi
Guest
Posts: n/a
Default Re: (mel_2kgsr)
not hit VTEC?..explian...
what about dual valvesprings??...
ther gonna bind, he better be careful.
also, it woudl be best if it were dynotuned.
Old Nov 13, 2003 | 11:49 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (CleenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleenSi &raquo;</TD></TR><TR><TD CLASS="quote">not hit VTEC?..explian...
also, it woudl be best if it were dynotuned.</TD></TR></TABLE>
huh? the skunk2 springs are dual coil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">the VAFC says its kickin on but it doenst pull or sound like its getting vtec.
Old Nov 13, 2003 | 04:39 PM
CleenSi
Guest
Posts: n/a
Default Re: (ind3ciso)
never sed n e thing about the springs also...but ok i get it now...i dont know whats going on, check wiring to the vtec selenoid..or maybe replace it? ...i dont know what to say
good luck tho.
AllMoToRB18c
17
Mar 14, 2005 10:14 AM
99B16Si
10
May 4, 2004 04:15 PM
HatchBox
Nov 13, 2003 10:13 PM
HatchBox
Nov 12, 2003 02:26 PM
vtec-izm
Sep 18, 2003 08:43 PM
