Serious ignition problem, HELP!!!
Old Nov 12, 2003 | 02:05 PM
ITSTOCK's Avatar
Default Serious ignition problem, HELP!!!
D16a6 crx si motor going into a 89 crx hf. now before the motor got pulled out, it didnt run due to no compression but it did get spark and fuel. So the d16a6 went in, tryed tyo fire it over, and no spark. So changed dist. still no spark. Checked all grounds and connections and fuses, still no spark. So we put on a nother si harness i had laying around, and you guessed it, still no spark So right now we are at a stand still, becuase it cant be something inside the car and the cabin harness because it had spark before the swap. we changed dist. engien harness, fuses are good, grounds are all new bolts and are fine, all connections are perfect. Another weird thing is, if we turn the key to the *on position, it will get spark 2 times in a row, try to start the car then no spark. turn the key off and put teh key back to on and it will spark once then when we turn it over it wont spark. We are very confused and have no clue where else to go from here since we've covered everything we can think of. So please if you have any idea of what we could try please reply, im in desperate need of this car.
91crx-jace
17
Dec 4, 2008 10:08 AM
bmxbikes
Jul 16, 2007 11:27 AM
1 Fly SI
10
Nov 14, 2006 04:43 PM
ITSTOCK
Nov 14, 2003 07:45 PM
crxY-49
Nov 4, 2003 05:05 PM
