Serious problem after swap, we're stumped, diagnostic PROS check here!!!
Old Nov 12, 2003 | 02:02 PM
ITSTOCK's Avatar
Default Serious problem after swap, we're stumped, diagnostic PROS check here!!!
D16a6 crx si motor going into a 89 crx hf. now before the motor got pulled out, it didnt run due to no compression but it did get spark and fuel. So the d16a6 went in, tryed tyo fire it over, and no spark. So changed dist. still no spark. Checked all grounds and connections and fuses, still no spark. So we put on a nother si harness i had laying around, and you guessed it, still no spark So right now we are at a stand still, becuase it cant be something inside the car and the cabin harness because it had spark before the swap. we changed dist. engien harness, fuses are good, grounds are all new bolts and are fine, all connections are perfect. Another weird thing is, if we turn the key to the *on position, it will get spark 2 times in a row, try to start the car then no spark. turn the key off and put teh key back to on and it will spark once then when we turn it over it wont spark. We are very confused and have no clue where else to go from here since we've covered everything we can think of. So please if you have any idea of what we could try please reply, im in desperate need of this car.
Old Nov 12, 2003 | 02:22 PM
tinkerbell's Avatar
Default Re: Serious problem after swap, we're stumped, diagnostic PROS check here!!! (ITSTOCK)
can you expalin the
"weird thing is, if we turn the key to the *on position, it will get spark 2 times in a row, try to start the car then no spark. turn the key off and put teh key back to on and it will spark once then when we turn it over it wont spark."
a bit more?
why does it spark when you turn it to *on
Old Nov 12, 2003 | 02:27 PM
ITSTOCK's Avatar
Default Re: Serious problem after swap, we're stumped, diagnostic PROS check here!!! (tinkerbell)
Just liek i said, we hooked up a gun to teh spark plug wire and pulled teh trigger, and just with the key turned to teh on position, it blinked twice on teh gun. I have never seen this before and i just have no clue WTF is going on. I never seen a car make spark unless it was cranking over.
Old Nov 12, 2003 | 02:30 PM
tinkerbell's Avatar
the fuel pump primes etc?
the main relay good?
just cause it sparked before teh swap doesnt mean that it is not something outside of the engine bay...
Old Nov 12, 2003 | 02:47 PM
ITSTOCK's Avatar
The fuel pump wouldnt have anything to do with spark, but it is fine. Where is teh main relay? We didnt check that that i know of. Its weird because teh day teh motr came out it was sparking with the old engine but teh next day with this motr it doesnt, tahts why id say it isnt anything to do with teh car itself outside of engine bay.
Old Nov 12, 2003 | 02:52 PM
90crxb16a's Avatar
I believe you are going to find the distributor to be your problem.... find a known good one and try it along with new spark plug wires...
Old Nov 12, 2003 | 04:43 PM
ITSTOCK's Avatar
Default Re: (90crxb16a)
Its not the dist. because i tryed the hf dizzy, that was getting spark before we took teh hf motor out, and it doesnt get spark with the hf dizzy now.
Old Nov 12, 2003 | 07:03 PM
ThaReason's Avatar
The main relay is under the dash.
Old Nov 12, 2003 | 07:21 PM
ITSTOCK's Avatar
Default Re: (ThaReason)
Theres alot of stuff under the dash, ive never seen a main relay maybe u can describe it a little better? Also, would the timing with teh cam and crank marks make it not spark up if they werent aligned correctly? jsut a thought for something we could check.
Old Nov 12, 2003 | 07:24 PM
tinkerbell's Avatar
Default Re: (ITSTOCK)
you said there was NO spark?
the crank or cams lined up incorrectly would cause spark at the wrong time...
the main relay is about 3 inchs long by 1 wide and 1.5 high and is brown... (dont worry about it if your fuel pump primes OK)
Old Nov 12, 2003 | 07:36 PM
ITSTOCK's Avatar
Default Re: (tinkerbell)
NO spark whatsoever.
Old Nov 12, 2003 | 07:40 PM
Turbogixxer's Avatar
Back track the power. Do you have power to the coil? does it flash when you crank it? If you do not have power to the coil, follow the wire(s) back untill you have it (or start in the cabin harness, you said you replace the engine harness).
tinkerbell's Avatar
are you getting any engine lights?
what is the code?
Old Nov 12, 2003 | 07:44 PM
ITSTOCK's Avatar
Code 15, ignition output signal.
Old Nov 12, 2003 | 07:48 PM
tinkerbell's Avatar
isnt 15 the coil/ignitor?
make sure you have voltage at the blk/yel wire in the two pin connector at the distributor...
Old Nov 12, 2003 | 07:53 PM
ITSTOCK's Avatar
code 15 is ignition output signal, that doesnt nessecerily mean ignitor/coil, i assumed. see, the hf dist. made spark on the other engine before we took it out thats what leads me to believe its not ign/ciol.
Old Nov 12, 2003 | 08:01 PM
tinkerbell's Avatar
well, sorry to say, but your ECU is telling you there is a problem with your dizzy...
is there voltage on the blk/yel wire at the dist. ?
what else does 15 mean? the only thing Honda thinks it means is coil or ignition control module or broken wires between the above...
Old Nov 12, 2003 | 08:03 PM
tinkerbell's Avatar
the only other step after repalcing the dist. is replacing the ECU...
Old Nov 12, 2003 | 08:04 PM
ITSTOCK's Avatar
Tryed using the HF ecu and it still did teh same thing.
Old Nov 12, 2003 | 08:06 PM
tinkerbell's Avatar
is stumped...
Old Nov 12, 2003 | 08:08 PM
ITSTOCK's Avatar
We are too.... and also i appreciate your help
btw this is what the manual says cfor code 15: Ignition Output Signal missing or defective ignition output signal
Old Nov 12, 2003 | 08:30 PM
ITSTOCK's Avatar
He said he read 14.8 volts off the blk/ylw wire off the dizzy.
Old Nov 12, 2003 | 08:34 PM
tinkerbell's Avatar
sounds fine, now what ECU are you running?
what is the model number and out of what car?
if you are using the HF CRX one, now measure the voltage with ign on at A18 (-)and both B15 and B17 (+) on the ECU...
Old Nov 12, 2003 | 08:49 PM
ITSTOCK's Avatar
he checked teh ecu voltage and it read fine. Its a 89 crx hf with crx si engine.
Old Nov 13, 2003 | 07:18 AM
ITSTOCK's Avatar
anyone else have any suggestions?
