mugen thermostat is it worth it?
Old Sep 10, 2001 | 10:47 AM
tsjag17's Avatar
New User
Default mugen thermostat is it worth it?
is it worth having it? is it worth the 50$ or what should i do? should it make a performance difference... or what?
Old Sep 10, 2001 | 11:08 AM
3.3.3's Avatar
Default Re: mugen thermostat is it worth it? (tsjag17)
its a + for your cooling system. basically, it opens up at a lower temp than stock, thus cooling your engine before it gets really hot. i say its worth it.
Old Sep 10, 2001 | 12:15 PM
tsjag17's Avatar
New User
Default Re: mugen thermostat is it worth it? (spnhb)
and would it hurt my car.. i have a 2000 gs-r..
sk2 mani
dc sport headers
iceman cai
aem cam gears
itr cams
port and polished head
3 angle valve job
shaved 30 thou
and a 55 shot nos
with colder temp spark plugs
so would the mugen thermostat be any good for me?
Old Sep 10, 2001 | 12:40 PM
clockworks's Avatar
How much do they want for it? If it's comparable in price to a stock replacement (which I doubt a mugen piece is), go for it. Otherwise, no I don't think it's worth it. It won't cool the engine any more than the stock piece.
Greg
edit- I should have read the original post to get the price.
[Modified by clockworks, 10:15 AM 9/11/2001]
Old Sep 10, 2001 | 01:48 PM
Tripz's Avatar
New User
a cooler engine will run better and give better performance. I'd say go for it! u could also try some Redline "Water wetter" for additional cooler temps, however for those who experiance the winter months...i would swap back to the stock thermostat
Old Sep 11, 2001 | 05:25 AM
drift's Avatar
New User
in a word... NO. you can get a colder thermostat that has the same open temp as the Mugen thermostat for less than $20 at your local Pepboys or any other store. just ask for "Beck Arnley Worldparts" specifically, and tell them you want it 10 degrees colder than stock. stock is 180-185 degrees.
Old Sep 11, 2001 | 05:39 PM
MrDX's Avatar
Default Re: mugen thermostat is it worth it? (drift)
drift is right... you can get a 170degree t-stat from Pep Boys, NAPA...etc. 10degrees isn't worth $40 more, it won't make a difference, and will not hurt your car in any way. Try using the RedLine WaterWetter too... it knocked off an extra 4 degrees on my last car.
Old Sep 29, 2001 | 11:44 AM
CKim's Avatar
Default Re: mugen thermostat is it worth it? (MrDX)
Are there ANY disadvantages to running a cooler thermostat?
Old Sep 29, 2001 | 12:01 PM
92CivicSiR's Avatar
New User
Default Re: mugen thermostat is it worth it? (CKim)
No, there is not any disadvantages to runnnig a colder termostat.
Old Sep 30, 2001 | 06:27 PM
rioninja's Avatar
Not true, your heater wont be as nice and toasty
j/k
Old Oct 1, 2001 | 10:02 AM
betsuni's Avatar
it's worth it! go for it!
Old Oct 4, 2001 | 09:44 AM
Undrstm8ed's Avatar
New User
Default Re: mugen thermostat is it worth it? (92CivicSiR)
the only disadvantage to a cooler thermostat is if you are below 169 degrees... when the ecu see's this it puts you into whats called closed loop. in other words, it thinks the car still needs time to warm up causing more fuel to be dumped. this may sound good at first but its hard on the engine and the wallet, ( fuel in MI area is crazee)
Mr.DC2TurBo
Jan 24, 2004 02:06 PM
cloproductions
Nov 11, 2003 12:14 PM
LostLude
Feb 25, 2003 05:19 AM
97Silver SH
Jan 20, 2003 09:54 PM
io_burn
Dec 10, 2002 06:22 PM
