Shady Acura Dealer Work
So a while back I posted about my car turning to safe mode for no apparent reason, checked the code, it says vtec pressure switch. Take it into acura, they say oil pan is to dented (no oil pressure, no vtec)...ok, they change pan. THEN they tell me vtec pressure switch is bad...hmmm well I guess I got a new oil pan for no reason, I was upset but didn't care THAT much since they cut labor charges. Fast forward 5 months, my car starts to smell like burning oil...?.....smoke starts comming from the engine bay, #&&$@$& could this be!?!? Jack the car up see that there is oil dripping from both sides on the oil pan around where the header connects to the cat...and...wtf...there are a couple nuts and bolts missing from the oil pan. Well took it back in this morning and they said OOPS! Must have forgot to tighten a couple bolts and nuts on dat der oil pan. Talk about sketchy...blah...just happy the thing didnt fall off on the freeway, I wouldn't have even had time to turn the engine off before it seezed.
Clif notes: Oakland acura did some shady work on my car, resulted in some burnt oil and a scared monkey...
Yeah, make them fix it and double check their work before you leave the lot. Also you should always question whatever they do.
I wouldn't pay anything since it was their mistake and you possibly could've had a ruined motor.
oh yeah yeah I made them lift it and I checked it out, Ill never be back there, and of course I didn't pay anything it was there fault it was under their work warrenty, just some sheisty ****
Ive got a good engine, 60xxx miles and 235 compression across the board, no need for unwanted hassle, but it would have been great if I took a friends blown block and tricked um...
My friends gsr kept burning oil and they were about to give him a different gsr to replace it because they couldnt stop it. eventually they did so he kept the same one. keep going back and stand your ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TerribleOne »</TD></TR><TR><TD CLASS="quote">Ive got a good engine, 60xxx miles and 235 compression across the board, no need for unwanted hassle, but it would have been great if I took a friends blown block and tricked um...
nahhh fraud is bad mmmkay?
</TD></TR></TABLE>nahhh fraud is bad mmmkay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegon-gsr »</TD></TR><TR><TD CLASS="quote">how much did it cost for your vtec pressure switch and your labor</TD></TR></TABLE>
I dont remember I have to dig up my old reciepts
not only does the acura dealer sometimes mess up your car, my friend the other day went to get a gasket seal for his valve cover and it cost him like an arm and a leg when it should have been like 5-6 bucks, something a little cheaper i was thinking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost »</TD></TR><TR><TD CLASS="quote">actually integra valve cover gaskets do cost "an arm and a leg" compared to other cars with 8$ ones</TD></TR></TABLE>
That's weird; last time I bought a valve cover gasket, it was only $8. I got it at A&H Motorsports (www.ahmotor.com). That dealer mark-up is ridiculous.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiRevn »</TD></TR><TR><TD CLASS="quote">I check my car out right there on the dealer lot before I leave. Everytime, I always find something they forgot.</TD></TR></TABLE>
I think this happens because those techs are most likely on flat rate and want to rush the job. This is what happens when half *** mechanics don't take their time.
sol2hatch
Mar 6, 2006 10:45 AM
