Pic request: 17's with AZENIS
Old Nov 12, 2003 | 11:09 AM
Nameless RB26's Avatar
Default Pic request: 17's with AZENIS
Does anyone here have a picture of any 17 inch wheel with azenis tires?
On a Honda or not.
I have some 17's and I might keep them for my 240sx depending on how they look with the azenis's. I don't like low pro tires.
Thanks
Old Nov 12, 2003 | 12:06 PM
Default Re: Pic request: 17's with AZENIS (Nameless EJ6)
anyone? Or does anyone have comments on them for 17" rims?
Old Nov 12, 2003 | 01:17 PM
EpDarks's Avatar
MTK Kommander has then on his 240...
They are hot. I'm sure he'll chime in eventually...
Old Nov 12, 2003 | 11:08 PM
Default Re: Pic request: 17's with AZENIS (EpDarks)
cool thanks. I'll look for his car..
anyone else?
Old Nov 13, 2003 | 07:30 AM
anyone else?
Old Nov 13, 2003 | 09:51 AM
Chemicalviper's Avatar
its just a tire in 17 inch form ... whats the point.
Old Nov 13, 2003 | 10:02 AM
Default Re: (Chemicalviper)
I want to ******* see it on a 17 inch rim, that's the point.
It's not just a 'tire in 17 inch form'. Every tire is different. Are you that stupid?
Old Nov 13, 2003 | 10:09 AM
Default Re: (Nameless EJ6)
Stupid ? search it. found 17" rim on google with azeni's in less than 2 minutes.
Your stupid.
Old Nov 13, 2003 | 10:48 PM
Good for you and google. Why don't you go ahead and post the ******* picture then?
By the way, it's "you're". Maybe you can find some word structure help on google while you're at it. Who's stupid?
The reason I'm looking for azenis on 17 inch rims is because I'd like to see how the profile looks. I don't want a tire with low profile, but I don't want huge profile either. If you can't help me out then don't post.
Old Nov 13, 2003 | 10:53 PM
^jefs0ng's Avatar
Banned
I don't think azenis has to do with the profile, but the actual profile of the tire.. will show you the profile.. just makin sure.. do you know what all 3 of these #s mean? 205/50/17 and no actually haven't seen anyone with 17s+azenis..
Old Nov 13, 2003 | 11:13 PM
Default Re: (.jefs0ng)
Yes, I know what the numbers stand for. I have quite a bit of knowledge on this subject.
All I wanted was to see a picture of a 17 inch rim with the azenis tires.
And there's a good example. I like them.
Basically I was hoping the 17 inch azenis tires would look similar to how they look on smaller rims. Some tires are perfect on smaller rims untill you see them on larger ones. Ya know...? I need some meat on my tires...
Old Nov 13, 2003 | 11:45 PM
^jefs0ng's Avatar
Banned
Maybe azenis come in thicker profiles? you know that middle # is a percentage not a measurement right..
Old Nov 14, 2003 | 01:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">Maybe azenis come in thicker profiles? you know that middle # is a percentage not a measurement right..</TD></TR></TABLE>
It's actually more like a ratio of sidewall width/height. But yah I understand it..
After doing some more research on their available sizes.. (I thought they had more available) it looks like I'm left with these two decisions:
225/45ZR17
245/45ZR17
And ideas on what would work well for an S13 hatch?
Old Nov 14, 2003 | 01:09 PM
cre18's Avatar
good lord, those are beefy
Old Nov 14, 2003 | 01:22 PM
Thrashin's Avatar
Default Re: (cre18)
tire sizing
example 245/40/17
245 width, 40 percentage of width = sidewall, 17 wheel diameter
to figure out width and hieght of a tire you can use this formula, ill use 245/40/17 as the example
245 divided by 25.4 = 9.64 (the width in inches)
9.64 x .40 = 3.85 (sidewall hieght), multiply that x 2 and it = 7.71
add 7.71 to 17 (rim diameter) and it will give you the overall diameter of the tire
in this case
a 245/40/17 is
width = 9.64
sidewall hieght = 3.85
overall diameter = 24.71
seems confusing but once you know it, its easy
Old Nov 14, 2003 | 03:14 PM
EpDarks's Avatar
Default Re: (thrashin)
If it was my car...
I'd put the 245's in back... and the 225's in front. Of course I would also have different sized wheels.
Old Nov 14, 2003 | 11:55 PM
S14sx2nr's Avatar
245 is a little big for s13s and u need atleast an 8" wheel for them to fit nicely, go for 225's all around, unless your boosted, then u can contact me on AIM S14sx2nr and ill help u with your wheel/tire setup.
-Dan
GRANT!
Apr 1, 2010 05:44 AM
realazy
Nov 10, 2009 05:59 AM
JDM CF4
Jun 9, 2007 04:53 AM
FBP Si 2000
10
Dec 29, 2003 11:30 AM
CereaLand
May 26, 2003 10:09 AM
