Skunk 2 cams VS type r cams
Old Nov 12, 2003 | 08:56 AM
matt2001teg's Avatar
Default Skunk 2 cams VS type r cams
I know this has to have been discussed but I do a search...I have a 2001 gsr with basic bolt-ons i/h/e v-tec controller what cams do you think would make the most power with what I have....Skunk 2 stage 1's or the type r cams
Old Nov 12, 2003 | 09:30 AM
1hotintegra's Avatar
Default Re: Skunk 2 cams VS type r cams (matt2001teg)
i have skunk2 stage1's in my gsr ... love em only tyhinig is they cost a lil more than the type-r cams but do make more power... if ur interested in skunk2 stage1 cams let me know i can get them pretty cheap
Old Nov 12, 2003 | 09:54 AM
VTECorona's Avatar
Default Re: Skunk 2 cams VS type r cams (1hotintegra)
Like already said, skunk2 stage1's will make more power than any OEM honda cam whether it be GSR\ITR\CTR.
Old Nov 12, 2003 | 10:27 AM
Seedc2's Avatar
Default Re: Skunk 2 cams VS type r cams (VTECorona)
skunk2 will make more power but isnt it recommend that your upgrade your valvetrain if you are using skunk2's? you can use your stock valvetrain with itr cams.. which I am looking to get.
Old Nov 12, 2003 | 10:30 AM
VTECorona's Avatar
Default Re: Skunk 2 cams VS type r cams (kendogg)
They recommend it with all of their cams but they say that you will be fine using stock with stage 1's. Stage 2-3 need new valvetrain since they make power much higher in the rpm range.
Old Nov 12, 2003 | 10:43 AM
1hotintegra how much can u get the skunks for?
Old Nov 12, 2003 | 10:51 AM
crazzeboost's Avatar
VtecCorona Im running E/H/I and Itr Type R Cams, i didnt have to change anything and it is the same as the Stage 1 Skunk 2's. But my friend has the exact as me with Stage 1 cams and i dont feel a difference, at all. Its all personal preference.
Old Nov 12, 2003 | 11:13 AM
fiebru1119's Avatar
Default Re: Skunk 2 cams VS type r cams (crazzeboost)
you dont need to upgrade valvetrain until you start revving past 8K..
Old Nov 12, 2003 | 11:16 AM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazzeboost &raquo;</TD></TR><TR><TD CLASS="quote">VtecCorona Im running E/H/I and Itr Type R Cams, i didnt have to change anything and it is the same as the Stage 1 Skunk 2's. But my friend has the exact as me with Stage 1 cams and i dont feel a difference, at all. Its all personal preference.</TD></TR></TABLE>
if your saying you don't feel the power difference then thats very understandable. There isn't that great of a difference between the 2. Its not so much of a difference that you'll be able to tell just by riding in the car. The dyno numbers will be slightly better after tuning. Also, you and your buddy don't have the same exact motor, yes both are b18c1's but one may be stronger then the other, and one may have a better header then the other. One may react to mods better then that other, etc. There are quite a few differences to even come close to comparing. But feeling a difference between 2 cams that are pretty similar is tough. I have ITR cams and I can handle a GSr with skunk2 stage2's if its not fully modded like mine is. Im pushing 190whp and I have a 2,400lb GSR, I can handle a decent amount of turbo cars aswell. Too bad ill only have that power for about another week......I've ventured over to the darkside and gone turbo myself
Old Nov 12, 2003 | 11:21 AM
VTECorona's Avatar
It's not preference, this isn't about having "ARR cams" or skunk2 cams just to say you have one of the two. The butt dyno won't tell you which is stronger, on a dyno can do that. There is a difference but it isn't strong enough to feel a dramatic difference between the two while driving.
Mr Type R's Avatar
From what I have read and heard form many people, Skunk2 stage 1, and ITR cams put out about the same amount of power, stick with the OEM part more reliable. I was talking to this guy last week, that had S2S1 cams in an H22 in an EG, he told me that he cracked one of his cam shafts, while he was running. That says stick with the ITR cams.
Old Nov 12, 2003 | 11:26 AM
VTECorona's Avatar
Default Re: Skunk 2 cams VS type r cams (patdemps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">
I can handle a GSr with skunk2 stage2's if its not fully modded like mine is. Im pushing 190whp and I have a 2,400lb GSR, I can handle a decent amount of turbo cars aswell. Too bad ill only have that power for about another week......I've ventured over to the darkside and gone turbo myself </TD></TR></TABLE>
I dunno man, maybe you can own stage2'd gsr's untuned and on a shitty day. As for the turbo cars, I agree partially with you on that. You can probably beat a few since you have 190 whp, I know of someone with a SOHC VTEC del sol that only runs mid 14's. Cars like that, yea, but there is no way you are gonna roll with a turbo'd GSR or anything greater than that. Granted both drivers are equal.
Old Nov 12, 2003 | 11:28 AM
VTECorona's Avatar
Default Re: Skunk 2 cams VS type r cams (Mr Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Type R &raquo;</TD></TR><TR><TD CLASS="quote">From what I have read and heard form many people, Skunk2 stage 1, and ITR cams put out about the same amount of power, stick with the OEM part more reliable. I was talking to this guy last week, that had S2S1 cams in an H22 in an EG, he told me that he cracked one of his cam shafts, while he was running. That says stick with the ITR cams. </TD></TR></TABLE>
About the same power, yes, on the butt dyno. As for the cam breaking, that's probably the installers fault.
Old Nov 12, 2003 | 11:30 AM
neo1z's Avatar
Doing about 190 whp pre-pistons on Skunk2 Stage 1's right now. Just VAFC tuning. Whether or not they feel alot different than ITR's, they are much more powerful.
Old Nov 12, 2003 | 12:16 PM
player2z's Avatar
I have the CTR Cams in my car, I feel that my car hasnt had more power. I was told that skunk 2 are better.. Dont get type r cams!!!!!!!!!!
Old Nov 12, 2003 | 12:37 PM
patdemps's Avatar
Default Re: Skunk 2 cams VS type r cams (player2z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player2z &raquo;</TD></TR><TR><TD CLASS="quote">I have the CTR Cams in my car, I feel that my car hasnt had more power. I was told that skunk 2 are better.. Dont get type r cams!!!!!!!!!!</TD></TR></TABLE>
Do you have a reason for saying not to get ITR cams.....
ITR cams (oem reliability, great midrange to upper power). Probably the best bang for your buck cam on the market. All cams are also more powerful after you tune them. Just slapping them on is a good power increase, but the tune definately adds to their potential.
Old Nov 12, 2003 | 12:39 PM
player2z's Avatar
If u r gonna spend money on some cams get something thats worth ur money!! Something other than oem
Old Nov 12, 2003 | 12:45 PM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">
I dunno man, maybe you can own stage2'd gsr's untuned and on a shitty day. As for the turbo cars, I agree partially with you on that. You can probably beat a few since you have 190 whp, I know of someone with a SOHC VTEC del sol that only runs mid 14's. Cars like that, yea, but there is no way you are gonna roll with a turbo'd GSR or anything greater than that. Granted both drivers are equal.</TD></TR></TABLE>
Well lets see. In my days at the track I have taken down: a few turbo GSR's, a bunch of ITR's, GSX and GST eclipses, TSI talon, SR20DET in one of my friends nx's. On the street I have taken an SRT-4 and plenty other cars. I have a wonderful thing called a camera too to witness all the track events and mostly all of my street races. I'd say thats quite a few turbo cars for an All Motor teg. I know I can get my *** handed to me by most turbo cars, but that by all means doesn't mean all of them. Its take quite a bit more hp from a turbo car to beat a 190whp all motor car. Especially since i've got an lsd and can launch my car very effectively. I've got a Type R tranny to go along with it for great gearing. Yes, I know ill have more power once I go turbo, but that won't ever take away what 190 vtec whp sounded like...and by all means how it pulled
Old Nov 12, 2003 | 12:58 PM
VTECorona's Avatar
Good stuff man, I wasn't calling BS or anything I just wanted some clarification. It's all about the driver
Old Nov 12, 2003 | 03:16 PM
babes 99 GSR's Avatar
patdemps - that is exactly how i want my teg...good stuff. I want the toda spec bs though. Man, i need more money faster!
-Staci
Old Nov 12, 2003 | 03:21 PM
P1mpSlap's Avatar
bleh get some EF-1 M24s
[/end thread]
Old Nov 17, 2003 | 09:18 AM
Teggy94's Avatar
type-r's
Old Nov 17, 2003 | 09:48 AM
Hairy Gorilla's Avatar
Default Re: (Teggy94)
What would you guys recommend getting in conjunction with type R cams. I have I/H(jdm 4-1)/E/Cat. Do i need to build the engine anymore? Maybe a VAFC? Can you tune that yourself or is it recommended to take it to a dyno.
Old Nov 17, 2003 | 10:19 AM
VTECorona's Avatar
Default Re: (Tim Maryak)
VAFC and\or skunk2 intake manifold.
Best to get it dyno tuned because every car is different. You could end up with as little as 0-5 hp from tuning or up to 10-12 with those cams. You will need adjustable cam gears too
Old Nov 17, 2003 | 11:03 AM
Justin95GSR's Avatar
Hey man i got type R cams in my GS-R and I like them alot. They are not as agressive as skunk 2 but they made my car about 2 or 3 car links faster on my car with intake and exhast. If you get Skunk 2 intake mainfold your top end is nasty my car has I/H/E intake mainfold and type R cams and vtec controller now and my car with the cams and intake mainfold my car hit vtec and kick and it kicks again about 6100 rmps because of the cams and intake mainfold. But skunk 2 might be faster but i have no interials and i take my car to 8300 or so sometimes and it has had no prombles yet.
codeh22a4
Sep 21, 2004 02:27 PM
1gen crxer
11
Mar 22, 2004 05:01 PM
sharkey65a
Feb 27, 2003 06:00 PM
skellator_thoj
14
Oct 4, 2002 04:42 PM
.Ryan
May 11, 2002 09:27 AM
