Will a clutch used with a cable tranny work with a hydro tranny?
Old Nov 12, 2003 | 08:47 AM
BseriesHatch's Avatar
Default Will a clutch used with a cable tranny work with a hydro tranny?
Just like the topic says.
Old Nov 12, 2003 | 08:58 AM
roadawg's Avatar
Default Re: Will a clutch used with a cable tranny work with a hydro tranny? (BseriesHatch)
From my experience it won't. I bought a 94 del sol VTEC clutch and tried to use it in my J1 tranny and it fit, but it was way too loose and would have shattered after 5 minutes.
I know you are asking about cable to hydro, but I figure trying to put a hydro clutch on a cable tranny would be the same thing.
Hope that helped.
Old Nov 12, 2003 | 09:01 AM
EL Vap133's Avatar
Which cable tranny do you have? 92+ or 91-?
Old Nov 12, 2003 | 09:06 AM
Default Re: Will a clutch used with a cable tranny work with a hydro tranny? (EL Vap133)
A J1 tranny. I might get a gsr tranny and was wondering if the clutch i'm using now would work?
Old Nov 12, 2003 | 01:48 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesHatch &raquo;</TD></TR><TR><TD CLASS="quote">A J1 tranny. I might get a gsr tranny and was wondering if the clutch i'm using now would work?
It will fit but it won't work.
You'll see what I mean when you try to install it.
Old Nov 12, 2003 | 09:41 PM
SiR Kid's Avatar
New User
Default Re: Will a clutch used with a cable tranny work with a hydro tranny? (hybrid honda)
The spline size on the input shaft of the tranny is 1 or 2 mm different. The 90-91 Trannie's input shaft is smaller than the 92+ trannies. It will rattle and end up shearing the center splines off the clutch disk over time.
I drove my car with a Clutchmaster's clutch for a 92+ Integra for 2 years, got DAMN lucky it held up so long, and when I turbo'd my car, the torque was too much, and it finally sheared the center out. Left me stranded when on lunch at work. Oops.
Old Nov 13, 2003 | 07:47 AM
Default Re: Will a clutch used with a cable tranny work with a hydro tranny? (SiR Kid)
Alright. So i guess when i get the tranny i will get a 92+ clutch disk. Thanks for the help.
Old Nov 13, 2003 | 08:27 AM
EL Vap133's Avatar
Yeah, better to be safe than sorry...
Josueneta
Jun 29, 2010 02:10 AM
Damills
Feb 15, 2007 03:32 PM
b18b1turbo
Dec 21, 2006 01:50 PM
Walterronny
May 27, 2006 04:12 PM
JDMracer17
Nov 9, 2005 08:33 PM
