Loud Sound when i hit bump, i think its shocks
Old Nov 12, 2003 | 05:31 AM
ImportStreetSeen's Avatar
Default Loud Sound when i hit bump, i think its shocks
I only here it in the winter time, everytime i hit a bump i hear a loud sound like metal is hitting the frame of the car, its only in the front, its hard to explain. if u can help me out if u can.
Thank
Old Nov 12, 2003 | 06:24 AM
GirlTech1811's Avatar
maybe if your car is too low your tires may be hitting your frame ... if you have lowering springs that could be the problem.
Old Nov 12, 2003 | 07:06 AM
Elvis1977's Avatar
Default Re: Loud Sound when i hit bump, i think its shocks (ImportStreetSeen)
nothing to worry about. It sounds like the rubber stopper on the struts is rubbing. Mine does the same when cold.
Old Nov 12, 2003 | 09:23 AM
iam7head's Avatar
Default Re: Loud Sound when i hit bump, i think its shocks (Elvis1977)
check cv axle, Tie rod, ball joints
Old Nov 12, 2003 | 07:48 PM
Import Driver's Avatar
My front end used to clunk. I unbolted the nut on top of the shock tower (strut tower) in the engine bay and put about 3 washers on top of the bushing, then put the nut back on tight. that took care of it.
you may have the same problem.
Old Nov 13, 2003 | 06:05 AM
Stew Pidasso's Avatar
Default Re: (Import Driver)
Is your car lowered? Does it have a camber kit? It could be the upper control are hitting the frame...
skiformance
Honda Civic (2001 - 2005)
Oct 31, 2007 12:46 PM
1993gsrcivic
Oct 30, 2007 10:09 AM
Lil Corb
Apr 25, 2004 06:10 AM
bocian
Oct 18, 2002 01:08 PM
Ass_Clown
Sep 15, 2002 11:39 AM
