B20 swap questions
Old Nov 11, 2003 | 10:15 PM
mooseknuckle's Avatar
Default B20 swap questions
Looking like i'm finally going to go threw on this b20.
I'm curious on a couple things.
1. Whats mounts will I need?
2. What ECU should I use, LS?
3. How can I make is possible to use my current DX ECU
4. Will i need a new intermediate shaft, if so which one?
I hope these are the last of my questions. Im just trying to figure out exactly what i need, so i can add it to the list.
Drew
Old Nov 11, 2003 | 10:39 PM
Newman's Avatar
New User
Default Re: B20 swap questions (mooseknuckle)
Put it this way. The B20B/Z longblock IS a B18A/B LS motor but bored out to 2.0L with 84m pistons. They both have the same rods, crank, etc. Oil pump is GSR/ITR but everything else internal wise is the same as LS (you use the LS main, trust, and rod bearings, if you use the B20/LS crank - also samething). You can swap the manifolds, distributor, sensors, etc, from your LS motor to the B20 2.0L block and drop it back in w/out any problems.... we've done that a couple of times for customers who wanted a newer, bigger B20 motor in their Integra LS cars.
With that in mind.....
1) Use the stock existing ones and pull the timing belt side bracket off of the LS and use that as well.
2) Use the LS ECU that is in your car.
3) Yes, the DX ECU will work but the fuel maps are designed for a SOHC motor, not a DOHC motor and is not recommended.
4) Use your existing intermediate shaft, clutch, tranny, axles, etc. Again, same physical size motor.... see above.
Old Nov 12, 2003 | 11:19 AM
Default Re: B20 swap questions (Newman)
I have a d16y7 motor. I dont have anything yet.
Thanks for the help thus far.
Drew
Old Nov 12, 2003 | 07:52 PM
come on..
someone has to know this..
Old Nov 12, 2003 | 07:57 PM
Se-rv-Tak's Avatar
I am doing the exact same thing as you... I have a d16y7 motor as well.....
You will need the following:
1.ECU-p75(LS) or a chipped p06 92-95 if you want to go obd1(that is my plan).
2.Mounts: You will need..... 99-00 SI rear bracket. b-series driver side bridge mount. (alot of people say alot of things...there are 2 sides to both, but I know from my friends swap, that is all you need).
3. B-series Axles.
4.Tranny- find some sort of b-series tranny that you will like to use... and bolt it up. Since the b20b/z is automatic...and most likely 4wd.
..... and if i forgot something please IM me... hope that helps.
Old Nov 12, 2003 | 09:30 PM
Default Re: B20 swap questions (Soon2B18Boost)
thanks so far.
Old Nov 12, 2003 | 09:54 PM
Se-rv-Tak's Avatar
any other questions?
Old Nov 15, 2003 | 07:38 AM
Rob!'s Avatar
me and mooseknuckle are both going b20. hes putting in a del sol and im putting in a 97 hatch...can anyone give me some input as well? im gonna start piecing everything together and hopefully have all my stuff by winter break.
Rob and bump for you drew.
Old Nov 15, 2003 | 01:24 PM
Se-rv-Tak's Avatar
Default Re: B20 swap questions (EKsnatchback)
search, or be specific on what you want to know
Old Nov 16, 2003 | 05:01 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mooseknuckle &raquo;</TD></TR><TR><TD CLASS="quote">Looking like i'm finally going to go threw on this b20.
I hope these are the last of my questions. Im just trying to figure out exactly what i need, so i can add it to the list.</TD></TR></TABLE>
It's hard to say exactly what parts you should get without knowing what year and model car you are working with. For all we know it could be a 1982 Yugo.
Old Nov 16, 2003 | 02:07 PM
Se-rv-Tak's Avatar
Default Re: B20 swap questions (VTECVillain)
lol 82 yugo? hahahaha. .. there ya go, that's a beast!
Old Nov 16, 2003 | 04:24 PM
Rob!'s Avatar
mooseknuckle has a 97 del sol S and i have a 97 civic dx hatchback. i know the basics such as what shift linkage tranny clutch flywheel...im confused on the little stuff such as throttle cable, which sensors are not used which extra ones i need. vacuum diagram maybe, basically the little stuff. and for the guy who told me to search...i have been searching for roughly 3 weeks and am not coming up with too much specifically what im looking for...thanks for tellin me though
Old Nov 16, 2003 | 08:39 PM
Maximus's Avatar
You will need a 94+ Integra 5 spd intermediate shaft. I have the intermediate shaft and shift linkage you will need to complete your b20 swap. Check my signiture below for details, you can save on shipping by purchasing both items.
Old Nov 20, 2003 | 06:53 PM
j-specB20sol's Avatar
Ok bro i just got finished dropping a jspec b20b in my del sol. here is what you will need:
1.Mounts ...hasport makes some sweet *** ones
2.axles... LS, SI, del sol vtec... basically any b series
3.intake manifold... you wont be able to close your hood with the stock b20 manifold...the is sits up like 6 inches... get an LS manifold
4.tranny... any b-series
5.ECU and wiring harness- LS... i have an LS wiring harness i will sell you for $75
6.jock strap... with the b20's torque prepare to have your ***** slammed into your throat
any questions or if you want that harness... email me
Old Nov 21, 2003 | 12:49 AM
kinvid22's Avatar
I just got a b20 swap into my 98 hatch last month. I did exstensive research. ask me a question.
Old Nov 21, 2003 | 04:53 PM
b20_ed's Avatar
Default Re: B20 swap questions (kinvid)
http://hybrid2.honda-perf.org/tech/6glaw.html
mikeledez
Nov 16, 2009 12:41 PM
bettsbanger
Sep 19, 2009 12:09 PM
EGandDArida
Jun 12, 2009 11:26 PM
REDekSI
Aug 16, 2007 04:39 PM
buddy club vx
16
Nov 19, 2002 10:58 PM
