blinker won't work?
Old Nov 11, 2003 | 09:58 PM
GotGSR's Avatar
Default blinker won't work?
Hey all, I'm new to the boards... I got a 95 GSR, and neither of my blinkers are working. I checked the fuse, it was blown, I replaced it with the correct fuse...still nothing. The hazard lights work fine... so i know its not the bulbs or the light unit itself. Any other ideas? Could it be the unit on the steering column? I'm new with actual work on cars...very few hours of wrench time if any, so if you got any ideas be VERY specific. Thanks alot guys!!!
Old Nov 11, 2003 | 10:01 PM
King_j's Avatar
Default Re: blinker won't work? (GotGSR)
you didnt check the bulbs?
go outside and check them
Old Nov 12, 2003 | 05:12 PM
GotGSR's Avatar
Default Re: blinker won't work? (King_j)
Nah i checked the bulbs the first time,they work great, guess i didn't make that clear. So any other ideas?
Old Nov 12, 2003 | 05:13 PM
thaiphob's Avatar
Nikon!!!
mabe you have a cut or bad wire somewhere?
Old Nov 12, 2003 | 05:25 PM
DrakeMK3's Avatar
I had the same thing happen on my old integra. Unfortunatly, I never pursued the solution. It's probably a wiring problem though. Ugh...I hate wiring gremlins.
Old Nov 12, 2003 | 05:28 PM
Jacob00527's Avatar
Look for shorts
Old Nov 12, 2003 | 08:01 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j &raquo;</TD></TR><TR><TD CLASS="quote">you didnt check the bulbs?
go outside and check them</TD></TR></TABLE>
he just said they hazards work!
Old Nov 12, 2003 | 08:47 PM
slo2kgsr's Avatar
Default Re: blinker won't work? (integraL)
possibly a bad switch on the steering column. i don't know the way to test it soo you have to look some where eles for that.
Old Nov 12, 2003 | 08:51 PM
631 Teggy's Avatar
Default Re: blinker won't work? (tegraLS97)
this may sound retarted - but do you hear an audible clicking noise to indicate that the switch in the stearing column is working?
Old Nov 16, 2003 | 08:37 PM
GotGSR's Avatar
Default Re: blinker won't work? (631 Teggy)
NO i dont. It's a very good point...whcih is why im thinking it might be the steering coumn switch.
Old Nov 17, 2003 | 03:53 AM
GSRBoy's Avatar
it probably isn't your steering column, same thing happened to mine. There are two locations for fuses pertaining to the turn signals I believe, one under the dash on driver's side, the other in the under-hood fuse box. I checked under the dash and all was fine and didn't know what the hell was wrong, so I took it to a friend and he pulled a fuse under the hood that was blown, replaced it, and now it works fine.
hope that helps a little,
MAtt
Old Nov 17, 2003 | 04:22 AM
IntEGNYC's Avatar
Default Re: blinker won't work? (GSRBoy)
time to bust out the voltmeter. also check the ground.
Old Nov 17, 2003 | 02:35 PM
GotGSR's Avatar
Default Re: blinker won't work? (IntEGNYC)
I checked both fuses already, their both fine. where's the ground located?
ty_uni_ek08
Sep 10, 2008 07:26 PM
eghatchin
16
Apr 25, 2008 04:46 PM
wardseg6
Dec 27, 2007 05:52 PM
bogus_ek
Feb 9, 2005 06:47 AM
ferio 95
Mar 10, 2004 07:48 PM
