JDM Swap or keep it??
OK, should i spend the $2500+ to buy and swap in a JDM H22A or should i just rebuild my H22A1 with performance internals. the only thing is that i have around 217k miles on the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeSpeed »</TD></TR><TR><TD CLASS="quote">OK, should i spend the $2500+ to buy and swap in a JDM H22A or should i just rebuild my H22A1 with performance internals. the only thing is that i have around 217k miles on the engine.</TD></TR></TABLE>
build the **** out of your usdm one. no point in spending all that money to be back where you started, stock. dont matter how many miles, it will have 0 when your done.
what kind of goals you going for..n/a, turbo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">
what kind of goals you going for..n/a, turbo...</TD></TR></TABLE>
I could not agree more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 »</TD></TR><TR><TD CLASS="quote">
I could not agree more.</TD></TR></TABLE>
Werd!
-Jeff-
Werd!
-Jeff-
i would rebiuld with hard core internals and turbo! you can get like 280 at 5-6 psi stock just think what a little tuning and more boost would do. turbo!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX »</TD></TR><TR><TD CLASS="quote">most definitely a rebuild bro, you'd probably end up saving some cash in the long run to go with a turbo
exactly. Or just spend the whole $2500 on rebuilding this motor. You could push out a lot more ponies doin that than buyin a jdm swap and gettin only 10 hp more.
</TD></TR></TABLE>exactly. Or just spend the whole $2500 on rebuilding this motor. You could push out a lot more ponies doin that than buyin a jdm swap and gettin only 10 hp more.
I'd go NA and spend more time at the track. $2500 is a lot of money that is only what it costs if you do the swap yourself even more if you get a shop to do it. so say $3000. I'd get Type-s pistons balance everything, thinner head gasket, cams, springs, retainers, manual tensioner conversion, mild P&P, LSD, brake pads, tires and dyno tuning time. If nothing else it'd be cheaper than going with FI. $3000 to go with a JDM will get you what 10-15 HP and another 100K miles worth of abuse? But if you build the engine it will be like 30-35HP and the same amount of miles if done right. Just my $.02.
